Hello everyone,
The link for the .mkv to Blu-ray without reconverting guide no longer seems to work. Does anyone know if the guide is still accessable on another web page? The only thing I don't remember is what to do with BDEdit. Any help would be greatly appreciated. Thanks.
Results 1 to 9 of 9
Apparently the site is gone.
But you could try this as it appears to have similar information:
http://www.bitburners.com/articles/convert-mkv-files-to-blu-ray-or-avchd-for-playstati...-tsmuxer/4019/ -
It's easy really, only a verification process.
-In BDEdit open the folder with your blu-ray structure.
-In the PLAYLIST tab, click Read and check to see that the height is indeed what you selected (480p, 720p, etc.)
- In the CLIPINF tab, click the Read again and check for the same thing there too.
This ensures that your "blu-ray" on your hard drive is in sync with each of its folder components. If you've done the previous work accurately this step is unnecessary other than for piece of mind.
Then it's safe to burn with UDF 2.5.
Hope it helps until the link is restored (if restored).I hate VHS. I always did. -
Thanks for the quick replys guys, what i was trying to extract was how does one use BDEdit with an odd resolution video file (say, 1280x544) to hex edit it so the Blu-ray player will think it's a 1280x720 file. Also, does anyone know how to do the same thing with 1080 files that are oddly resized? (like 1920x800).
Thanks again in advance! -
As that guide was concerned, the "resizing" or "tricking" was with the hex editor, and the BDEdit part was just verification.
The numbers you have to change, if you remember where, including 1080, are:
1 -> 480i
2 -> 576i
3 -> 480p
4 -> 1080i
5 -> 720p
6 -> 1080p
7 -> 576p
Not sure how BDEdit does any "edits" though. The guide didn't show anything there.
I personally believe that guide was removed because it may have been perceived as being piracy-centered. Keep in mind, that guide won't get your content to BD if it wasn't properly encoded in the first place such as having B-pyramids, too many ref frames, etc. It's only a "hack" to trick the BD player into thinking it's a certain size if the streams are pseudo compliant.
I did like it for reference and knowledge, but prefer instead to re-encode my personal video from the source for BD playback. I could care less what streams are found on Bittorent and don't care for "hacks" to get them playable.I hate VHS. I always did. -
GO TO THE STORE AND BUY SOME!! I'M PRETTY SURE THEY HAVE SOME IN KANSAS!!!
badboyzz, Please try to stick to the author's first post in each topic, if you want to discuss something else, create a new topic.
Moderator redwudz
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Any All-In-One Program That Really Works:Blu-Ray to MKV?
By bht42 in forum DVD RippingReplies: 5Last Post: 27th Oct 2010, 12:03 -
Multiavchd..Need Help..MKV-BLU RAY-- Freezing on Blu Ray Menu!!
By Thuglas in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Sep 2010, 23:58
