I'm trying to rip a PAL DVD, convert it to NTSC and reauthor it. So, I try ripping with MactheRipper and it tells me that the disc has bad sectors. Then when using Cinematize to make a MOV file, it gives me errors.
What can I do to fix this?
Results 1 to 9 of 9
I'm not sure if DVDFab Decrypter will help .give it a try
https://www.videohelp.com/tools/DVDFab_Decrypter -
Hm. I've got version 2.6.6.
I kind of solved the problem. Here's what I did. It's a disc with multiple episodes. So, I ripped each episode as its own title set. The seems to have worked. Not ideal, but it'll work.
Thanks for any advice. -
Version 2.6.6 was the last free version, and it cannot handle some of the newer forms of copy protection. So, as Case suggested, you need to get the latest version if you want a single-click solution (Case helpfully linked to where you can get it). It will cost you a nominal fee, but if you plan to do a lot of this kind of work, then it's worth it.
Read Case's post carefully. He gives you the link, just as I said in my post.
Mactheripper bad sectors when burning Disney movies
By TXMacUser in forum MacReplies: 10Last Post: 8th Feb 2010, 16:16 -
Bad Sectors on Rip from DVD
By AlfB in forum Video ConversionReplies: 6Last Post: 5th Jan 2009, 20:02 -
bad sectors/clusters
By stompinne in forum Authoring (DVD)Replies: 7Last Post: 17th Sep 2008, 14:13 -
Defragmentation leave lots of bad sectors on a new disk
By dmedina in forum ComputerReplies: 5Last Post: 25th Feb 2008, 13:25 -
Bad Sectors..
By SE14man in forum Newbie / General discussionsReplies: 10Last Post: 14th Sep 2007, 11:06
Can someone tell me how to obtain the latest version of
