Hi!
I'm having playback issues when i burn youtube clips on a DVD with DVD Flick. It converts and burns without any problem but when i play it in my Sony DVR the disc stops playback after each clip.
Im pusseled to what is making this, ive checked the options in DVD Flick and options like "play next title" when you finished playing is checked.
Anyone know a solution to this? You are more than welcome to share it with me!![]()
Does same happens if you use a software dvd player?
Tried latest beta 1.3.0.0 from http://www.dvdflick.net/forums/viewtopic.php?t=534 -
Nope, it seams to work just fine, at least when i played it in VLC.
Okay, i can try that beta, and see if it works.
Edit: The beta wont load files even. A good thing i found out though is the disc plays perfectly in my Panasonic Dvd-Vhs player. It must be something with my Sony player that doesnt match.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
Conversion ends with NO-FILE
By Tobias0815 in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2008, 05:31 -
DVD+RW ends up useless
By woodlander in forum Newbie / General discussionsReplies: 1Last Post: 25th Sep 2007, 12:32 -
My AVI file ends up too big after edits!
By enutz in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2007, 11:34
