Hello,
I've tried exporting to DVD and to MPEG and am getting these lines when there is fast motion as in this shot. My source is video captured from my Panasonic PV-GS320 via PE3.
Any idea what is causing this and how to get rid of it? Thanks!
that's normal interlacing not seen on tv's
just another reason why a tv monitor is needed when editing
you can check for color correction, field order, etc... -
That's the finished file, not a capture of the edit screen. Still the case?
As said this is what interlace video looks like on a progressive computer monitor. You are seeing two fields as a frame. It will look normal on a TV. On a computer you would use a deinterlacing player like PowerDVD or VLC. Progressive HDTV sets have internal hardware deinterlacers.Originally Posted by Captain SatelliteRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
crop in avisynth causing tearing ?
By davexnet in forum Video ConversionReplies: 13Last Post: 2nd Mar 2009, 16:17 -
What is causing this?
By edyohome in forum Software PlayingReplies: 5Last Post: 31st Oct 2008, 18:38 -
Besweet causing problems?
By hardcorejason in forum Video ConversionReplies: 1Last Post: 27th Apr 2008, 14:59 -
AVI2DVD causing computer to shut down
By Lynxer in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 10:42 -
B-frames causing weird pixelation.
By electrodaveultra in forum ffmpegX general discussionReplies: 2Last Post: 13th Aug 2007, 18:42
