Post the avisynth script. You can test avisynth scripts by loading them into virtualdub.
Frankly, I would not use WinAVI for anything. There are far better alternatives.Read my blog here.
here it is.
#################BEGIN#################
LoadPlugin("C:\PROGRA~1\GORDIA~1\DGMPGDec\DGDecode.dll")
LoadPlugin("C:\Program Files\GordianKnot\AviSynthPlugins\Undot.dll")
AVISource("I:\clip.avi") EnsureVBRMP3Sync()
part1=Trim(48206,63984)
part2=Trim(66046,82661)
Dissolve(part1,part2,120)
FadeIO2(100)
undot()
###############END###################
I was only looking to use WinAVI mobile for speed. just for quick viewing on my phone, the video quality wasn't too much different than Nero Digital, but much faster. only problem is no sound, and when looking under "Advance Options" with WinAVI, there isn't an audio track to select. Is there another encoder on par speed wise that accepts .avs files? thanks for the response. -
If you open this in virtualdub or media player classic, do you get audio ?
Read my blog here.
Urgent help needed pls. converting mp4 to xvid- cant get sound
By prendersparty in forum ffmpegX general discussionReplies: 4Last Post: 14th Sep 2010, 14:35 -
.MP4 for mobile phone problem
By the_provider in forum Video ConversionReplies: 0Last Post: 25th Dec 2009, 20:49 -
DVD to H264 (mp4) for Nokia mobile
By EpiMann in forum DVD RippingReplies: 1Last Post: 24th Jan 2008, 06:33 -
Loss of sound after converting with WinAvi
By TheGift73 in forum Newbie / General discussionsReplies: 1Last Post: 4th Aug 2007, 10:26 -
MP4 on WiMP Mobile?
By Memo_182 in forum Portable VideoReplies: 3Last Post: 7th May 2007, 16:34
