HI,
I am wanting to use on a Portable DVD player that definitely plays Divx a few different types of files.
I have folders named as such in thsi 3.5GB file selection I want to burn..
MP3 files 1 (with MP3 files)
MP3 files 2
MP3 files 3
Audio (with other MP3 files in it)
CSS Tutor (with divx.avi files that work on desktop)
Video ( With more divx.avi video)
Olympix ( many jpg files)
I use Nero 8 and whilst it burns just divx avi files okay which the player reads and all the rest separately \, I can't get it to read when i have them all on the selection.
I have burnt as a DVD Data multi session and NO multi session but the player says.. unknown disc.
What am I doing wrong?
ozstar wrote:
What am I doing wrong? -
In order to burn a Divx video that will play on most players, you have to observe a few guidelines. I borrowed this from a post jman98 made about what won't usually work with a set top player:
Originally Posted by jman98
I would also leave Nero out of the operation, though it usually burns data DVDs with no problems.
To make compatible Divx files easier, use a program like AutoGK. You can also try a program like AVI ReComp to make your AVI type file compatible.
I'm not entirely sure what you are trying to do. It sounds like you are trying to create a mixed media data DVD. If so, I could see problems with most set top or portable players.
If all you are wanting to do is to burn your files properly to a DVD, I would also recommend ImgBurn. -
Also, not all players will see all formats at the same time. I have a Pioneer player in a cupboard somewhere that happily plays mpg video, mp3 audio and jpg stills from CD or DVD, however it will not see all of them, even if they are in the same folder. if you want to play mpg files you have to tell it that is what you want, and that is all you will see. Tell it you want to play mp3 audio, and it will show you only the mp3 files. It is a stupid design, but not uncommon, even amongst newer media players. Perhaps you have to tell your player what to look for.
Read my blog here.
Thanks.. I have been using SUPER to convert the flvs and regular AVI's to Divx and they all work fine but it is just when i put them all on the same DVD.
Yes it looks like I am best at the moment to put the avis on one, jpgs on another mp3's on another.
As far as the jps go, I have 3000 of them in different folders and most named 10000.1.jpg etc so I can't put them all in the same folder.
What is the best way to DVD these? Maybe each folder a chapter I guess, although I have 40 folders.
Thanks thus far guys..
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
