I need some help. The videos I convert to .FLVs are very choppy, even though my settings look good.
I uploaded an image with my settings.
Here is the choppy video:
http://www.youtube.com/watch?v=REKbjU1-XXg
Any help would gladly be appreciated, thanks.
There seems to be a bug in ffmpeg when it comes to converting to FLV and needing to invert the stream mapping.
There is a workaround if you have QuickTime Pro.Last edited by Case; 3rd Apr 2010 at 10:21. Reason: Links updated for the new forum
I hope this bug is eradicated soon. Thank you Case for the workaround that you have provided, I will try it as soon as I can.Originally Posted by Case
Oh, by the way, I have to invert the stream if not then FfmpegX returns with an error. Strange
Converting MOV to FLV is not working - Please help
By hopeisnotastrategy in forum ffmpegX general discussionReplies: 5Last Post: 6th Feb 2011, 17:31 -
problems converting MOV -> FLV
By dannyboy2090 in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2010, 12:50 -
Converting .mov or .avi to flv does not work
By Alainb2809 in forum ffmpegX general discussionReplies: 22Last Post: 11th Oct 2010, 13:33 -
help converting MOV to FLV and aspect ratios
By erichazann in forum Newbie / General discussionsReplies: 2Last Post: 29th Jun 2009, 13:16 -
Issue converting a .mov to a .flv
By bopdro in forum ffmpegX general discussionReplies: 1Last Post: 5th Mar 2009, 12:15
