hi all friend, sorry about my bad english i serch the best solution for build a avchd on dvd-r type 5 or 9 from my camcorder sony hdv hc3.
i wont use tsmuxer and tsremux with my video clip hdv format m2t is not recognized![]()
give my a best solution for create avcd dvd-r wonderfull quality from my video clip hdv .
thanks a lot
leone
Results 1 to 16 of 16
LEONESVIZZERO -
I have the HC7 camera and use Ulead's latest version of VideoStudio to convert my HDV footage to AVCHD and burn on a DVD9 to play on Bluray players. Works very well and allows you to create dynamic menus. You can try the demo on Ulead's website but I don't know if the demo is striped down or limited (except for the limit on number of days, of course). -
so menus can be made with the AVCHD method...interesting
I was going to burn m2t without menus
VS can't write HDV back to cam -
Correct me If I'm wrong, but won't Blu Ray support Mpeg2 Transport Streams as source files? If he's got HDV as source, then maybe the conversion to AVCHD isn't needed.
HI friends, i have make a little tutorial please see my file image STEP_CONVERSION.jpg
i have follow this procedure the step number 5 is
i am waiting your help.
bye Leone
Originally Posted by TuxOmatic
hi tuxomatic you use only video studio 11,5 for capture -editing - encoding - burning to avchd dvd 9 ???
give my your setting parametries for best encoding to avchd format with video studio ???
how minuts of video avchd on dvd9 for regolar video from your video hdv ???
how minuts of video avchd on dvd9 if you build a slide shop photo ???
you have tested another sw authoring as dvdmovie factory 6 plus ???
bye i am waiting your important information
leone from italy -
Yes indeed you can do that straight forward just burn the MTS files (be sure you change the extension file as MPEG) using nero or whatever burner software you have (just change to UDF 2.5) and youll be able to play DVD disc with HD content on a bluray player. I have sony bdp-s1 and the files play flawlessly. If you need menus and authoring you will need DVDit pro.
best regards -
Same problem here, have HDV files from my HC3E and would like to convert to AVCHD to be able to put more data on the DVD than with the native 25MBPS MPEG-2 Codec.
I tried Nero vision but it does not produce good quality AVCHD files (HD CINE/720/5MBPS or HDTV/1080/11MBPS) with some noticeabe "strobinge (probably bad handling of interlacing).
Sounds like VideoStudio might be the way to go ? Not sure if TS Remux can do that ? -
MeGUI with the x264 blu-ray profiles will convert to blu-ray AVC for you.Originally Posted by webvanI wouldn't entirely blame Nero here. AVCHD is not AVC blu-ray content - it's a "lesser form". It's a format developed so cameras can use it, and a differentiated consolation format in the event that Sony had lost the war to HD-DvD. I believe it will die now that BD is exclusive and tech will advance. But if you want "AVCHD", then I can upload MeGUI profiles for you, which were put together by Racer-X, a community member on this forum.Originally Posted by webvanI hear that the AVC it produces is bad. But then again, I haven't tried it.Originally Posted by webvanIt will mux into a BD structure for you without loss. It will not however check for compliance or re-encode anything to another format for you.Originally Posted by webvanI hate VHS. I always did.
Hi again. Actually I don't have to upload them. You can check Racer-X's first post in this thread to get them.
https://forum.videohelp.com/topic348693.html
Burned on a DvD, it will not play in all BD players (of course). But of all the BD players that have the "AVCHD" logo I have tested this on, all is well.At least with MeGUI you can try different deinterlacing options that may have better results.My main problem with the Nero produced AVC files was the "strobing" that I suspect come from bad handing of the original interlaced HDV content.I hate VHS. I always did. -
In regards to the text above that I made bold ... did you try a PS3 by chance? Will it work on a PS3?Originally Posted by PuzZLeR
Hi John.
I've made a friend through bribes :P at a certain electronics store chain who allows me to continually try my encodes on several BD players, but no I haven't done any testing with PS3. I certainly don't see why it shouldn't play it though since it accepts AVCHD, and it's the ultimate multi-media machine today.
And that's why I avoided doing tests on the PS3 to be honest. The fact that something plays on a PS3 may lead to a false sense of security about overall compatibility among BD players.
But next time I'm there I can run a test for you if you like.
PS: If anyone's interested, the LG line of stand-alone BD players have been the most impressive. They seem to play almost anything, even the wrong specs.I hate VHS. I always did.
HDV .m2t footage - Best quality conversion to MPEG4- method/tools
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2012, 02:30 -
HDV M2T not bluray compatible
By FrontierDK in forum Video ConversionReplies: 4Last Post: 2nd Feb 2012, 10:33 -
HD camcorders: AVCHD vs .M2t base format
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2011, 11:44 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 05:03 -
What is the best /.m2t/HDV file player(s) for the PC?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 28th Sep 2007, 18:04
