Last night while using my PC I restarted my computer and XP went into this scan mode where it was saying stuff about orphan files, etc.
After it was done, my external HDD's games and DVD collection where erased or mixed together ( I played a clip and it kept flipping between pieces of different films).
I didn't have anything pirated or illegal.
I used my drive as storage for games like COD4 and back ups of some DVDs I own.
Anyways, most of the media folders are okay like pics and stuff. At the same time, my Samsung Lightscribe DVD burner drive won't play DVDs right, but my regular and much older one will. The good drive gets all pixelated and choppy at certain parts of a movie, even when reading straight from the original disc.
I've always used DVD Shrink and DVD Fab, but now they both freeze or say that can't read a DVD. I've used both like 10 times, and never had a problem.
I'll watch those same parts with the older drive and it plays fine.
I'm trying to copy the Rockford files Season 1 Disc 1 which is a double sided disc. I'm not sure if that helps.
I'm frustrated and confused.
				Results 1 to 9 of 9
	is the external usb? sounds like something wasn't done writing to the drive when it was shut off. use a disc drive file checking utility to verify the drive. right click on it/properties/tools/error checking if you want to use the windows one. --
	I'm reinstalling my stuff and have another question. I've also got DVDFab and Shrink again. I'm guessing that my drives didn't like the Universal 2 sided disc. I put in "Blood Diamond" and it took with DVDFab the first time. Here's the deal though, neither Recode or Shrink will burn properly. I've posted the error from Recode so maybe someone could kindly explain it to me.
 Project type: Main Movie to DVD
 Target size: DVD5 (2282925)
 01:30:47 File LangStreamPatcher.cpp, Line 56
 Command table patching started...
 01:30:47 File LangStreamPatcher.cpp, Line 133
 All tables successfully patched!
 Burn settings:
 Target: TSSTcorp CD/DVDW SH-S182M
 Number of copies: 1
 Write speed: 0 KB/s
 Temp folder: H:\DVDburn (443270393856 bytes free)
 Direct burning: false
 Target media: DVD+R/RW, DVD-R/RW, DVD-RAM, DVD-R DL, DVD+R DL
 Shutdown when finished: false
 Advanced Analysis: true
 Compress Adaptive: true
 01:31:54 File burn_dvdfiles.cpp, Line 231
 Compile DVD: init
 VTS_01 Title Vobs [17179 vobus] 4463.83MB -> 3518.08MB [R 1.00]
 Video: 2810.95MB, extra: 707.13MB
 Audio: 4 streams
 0. 0. Dolby Digital 5.1-ch English 469.96MB [enabled]
 1. 1. Dolby Digital 5.1-ch French 469.96MB [disabled]
 2. 2. Dolby Digital 5.1-ch Spanish 469.96MB [disabled]
 3. 3. Dolby Digital 2-ch English 201.00MB [enabled]
 Subpicture: 5 streams
 0. 0. English 2.61MB [enabled]
 1. 1. French 2.30MB [disabled]
 2. 2. Spanish 2.84MB [disabled]
 3. 3. French 0.34MB [disabled]
 4. 4. Spanish 0.34MB [disabled]
 01:31:54 File burn_dvdfiles.cpp, Line 1152
 Compile DVD: begin copy 1
 01:31:54 File NeroRecorderBase.cpp, Line 488
 Writing to disc: DVD-R
 01:31:54 File NeroRecorderBase.cpp, Line 502
 Free capacity on disc: 2286468 sectors (2298496)
 01:31:54 File burn_dvdfiles.cpp, Line 684
 Compile DVD: begin deep analysis
 01:33:31 File burn_dvdfiles.cpp, Line 381
 Failed to read from the file * ^.
 01:33:31 File burn_dvdfiles.cpp, Line 382
 Compiling DVD volume failed
 01:33:31 File burn_dvdfiles.cpp, Line 301
 Compile DVD: exit
 01:33:31 File burner.cpp, Line 961
 Failed to read from the file HÞ¯Š.
 I don't understand this technical stuff.
 Thanks, I'm almost back to normal
	You have backups, right ? Everyone does. You have anti-virus and firewall ? If you're reinstalling over a broken Windows ... well, you can try. Cross-linked files ... badness ... just a likely to have stuffed your windows up too. Google it, it's worse than you think.
	There wasn't alot of important stuff that I couldn't just reinstall on that drive. I'm just trying to figure out what that error means.
	check in the folder you ripped the dvd to. there should only be vobs ifos and bups and all of them should have normal names. nothing should look like the "HÞ¯Š" that shows up in your error report. that looks like the files on the drive are wacky again. --
	the error means your disk is stuffed up. google it. you'll be lucky if windoze works properly ever again if it's your system drive as there is potential for system files to be stuffed too.it was saying stuff about orphan files, etcfeeling lucky are we ?There wasn't alot of important stuff that I couldn't just reinstall on that drive
	Thank for your help guys, No, it's not my C drive that's messed up. It's my second HDD (H) that is. I'm using it as storage for my own video editing, and storebought back up DVDs, that's it. Last night I got Blood Diamond to burn all the way through and it plays fine, but seems a little fuzzy compared to other DVDs I burned that looked 1:1 to the real thing. I'm not sure if it was because my that movie was Full Screen. Anyways I'll try a Widescreen movie next to see if it looks better. Btw, the drive and the burner are almost brand new, and weren't cheap.
	Lucky you, being your non-system drive ! Know what ? I'd format it if I were you and then run an XP's exhaustive check on it (file system and sectors) before committing other info to it. If necessary try to copy/backup your "critical" files 1st. Buy a cheapie external USB hard drive $50-$100 and copy stuff to that as backup 1st. Just a thought.
  DVDFab HD Decrypter : Is DVD to HDD and Blu-ray to HDD decryption FREE?By Bonie81 in forum DVD RippingReplies: 2Last Post: 8th Jun 2011, 15:28
  Copying from standalone hdd recorder's hdd to pc hddBy flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17
  What format for VHS to HDD to TV? Playing off a HDD instead of DVD?By Rudyard in forum Video ConversionReplies: 10Last Post: 6th Aug 2009, 20:46
  HDD swap! Faulty 'Funai HDR-B2735' vcr/hdd/dvdr ... use HDD in a JVC ???By StuR in forum DVD & Blu-ray RecordersReplies: 6Last Post: 9th Oct 2008, 13:38
  PC HDD Driver for Panasonic DVD Recorder HDDBy SG-01 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 30th Aug 2007, 04:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
