When I try to convert and AVI file to iPod, by using x264
it takes some seconds and does nothing for the video and
begins to encode audio.
When a uncheck the "decode with quicktime" the things
work.
Any reason for this? Is there any problem with my quicktime?
Thanks in advance.
Alexandre Trovon
AVI can hold video and audio encoded with any from a large variety of codecs. Only some of them can be decoded with a default QuickTime. For some codecs you may need to install additional 'components' (plug-ins) to make QuickTime able to decode the content of the AVI.
Many DivX/XviD AVIs use part of the MPEG-4 specification (MPEG-4 Advanced Simple Profile) that is not supported by a default QuickTime (just MPEG-4 Simple Profile), e.g. encodings using B-frames.
The most popular solution these days is provided by Perian, a multi-codec decoder component that will help QuickTime decode (read) many formats. I'm pretty confident that Perian will solve your issue.
AVCHD - x264.exe has stopped working
By KlintIstwood in forum Blu-ray RippingReplies: 3Last Post: 27th Jun 2010, 08:17 -
Handbrake working with new version of x264
By levick in forum Video ConversionReplies: 7Last Post: 18th May 2010, 20:25 -
By newpath in forum Video ConversionReplies: 6Last Post: 17th Jul 2009, 16:42 -
FfmpegX x264 settings
By bvdw in forum ffmpegX general discussionReplies: 4Last Post: 20th Jan 2009, 13:23 -
Video not working after x264(MKV) to Divx/Xvid(AVI) conversion using TVC
By CthulhuSaves in forum Video ConversionReplies: 7Last Post: 3rd Jan 2008, 23:12
