I am not sure if this is the right forum to post in and if it is wrong pls redirect me to the correct thread. The problem is that I have a .h264 video extracted from a mkv file. Since the h264 video is of resolution 1280*720 my smaller laptop cannot handle it with its spec. I was wondering is there anyway to reduce the resolution of the h264 video without changing its encoding (the encoding codec is V_MPEG4/ISO/AVC ; you know standard for anime files) with existing programs, preferably without quality loss. I would prefer the output to be in h264 format so that I can remux it back to mkv. Thanx a lot for your help.
P.S. I have tried numberous conversion programs and things such as mencoder, menix, media coder .... They all failed because either I can use the program ( or its GUI version) or they just don't work. Again Thanx for your replies.
Results 1 to 19 of 19
The thing is that I am able to process the video no prob. My friend who primarily uses a laptop cannot stream the files even with coreavc. I was simply wondering if it was possible to reduce the resolution to use less cpu processing. If I go by the path of reconverting there seems to be no programs that can convert specifically to the h264 format. Most are able to go to mp4 or avi with h264 encoding. So is there a program that can convert directly to produce a h264 file from another format??? Thanx for your help Baldrick and anyone else.
If you need raw .h264 video convert to MKV or MP4 then demux the video stream.
Try this method,
http://forum.doom9.org/showthread.php?t=135795
Since you've already extracted use Megui to convert back to h264, avi or mkv...." Who needs Google, my wife knows everything" -
Sorry about the post above. Not thinking straight. It would be easier for it to be in a mkv container since I can use mkvextractGUI once again. I do need the raw.h264 so I can remux it. What I was trying to say in the above post is that would t0nee1's method be the one with the least quality loss? I am attempting to reduce the original raw h264 with a size around 300mb to something around 150-170mb. Already accounting the reduction in resolution, what would be the best method to reduce the size with least quality loss? Thanx for everyone's help again
Can someone please answer the question. I am trying to reduce a raw h264 720p to 400p (i.e. 300mb file to around 170mb file). So far I cannot find a program that can convert raw h264 into a reduced resolution h264 in a mkv container or demux mp4/avi properly. MeGUI was unable to convert the original h264 due to some error regarding not recognizing the source file (therefore no playback). Pls Help!!!!!!!!
If you want to reduce the resolution because your laptop can't even play 720p (Yikes! My almost 4 year old single core AMD CPU can handle that.) and MeGUI barfed on your input, for this file I'd say you need to just get on with your life and take what you can get. Convert it to Divx/Xvid with AutoGK or Dr. Divx (free, but restricted unless you buy the Divx codec to go with it) and you'll be able to play it back with little quality loss if you do it right. You can even keep the 720p.
jman98 and poisondeathray were faster than I,
so I could only add the following:
DivX/XviD is older than H264, and anime is much older than both.
The last I've heard, VC-1 in MKV is what's been dominant in the
Japanese P2P filesharing lately. -
Encode with a lower profile level, 4.2 or lower. The player is probably choking on 10 Reframes. Maybe even 3 b-frames.
Conversion by changing video resolution results in a bottom rainbow strip
By usta in forum Video ConversionReplies: 3Last Post: 17th Jun 2009, 03:59 -
Changing FPS of .h264 loaded in MeGUI w/Avisynth
By karpodiem in forum Video ConversionReplies: 8Last Post: 6th Apr 2009, 10:27 -
How to reduce resolution and video bitrate in XviD AVI files?
By hibbs in forum Video ConversionReplies: 2Last Post: 13th Jan 2009, 11:50 -
Converted video changing resolution.
By ZedFighter in forum Video ConversionReplies: 3Last Post: 22nd Aug 2008, 18:25 -
Changing Video Resolution
By Erf in forum Newbie / General discussionsReplies: 4Last Post: 25th Aug 2007, 22:16
