Hi
I am able to see video/audio only in gom player. all other player in powerdvd8,wmp,wmp classic are blank but their is audio. i installed kazaa mega codec pack 390 under default profile. what do u guys suggest.
	Does it happen with ALL video file types?
 I would uninstall the kazaa codec pack and just use ffdshow or just install the codecs you need. It could also be an overlay/video acceleration issue like you have to two monitors/tv and you have set the primary monitor to the one you are not using.
	To check for the overlay issue, try opening two instances of MPC. If one works and the other doesn't, then it is the video overlay. Otherwise, it sounds like a codec issue. While codec packs work for many users, they are also known to cause issues such as this which can often be impossible to fix. As noted above, try uninstalling the codec pack. Then use a program such as codecsniper to verify your remaining codecs.
 And from now on, install only the codec needed to get a file playable. You can open files in an app such as Gspot to see which codecs are needed. And then simply download and install only that codec.Google is your Friend
	i think it was overlay issue. as soon as i played around with the ati card utility it started working. but i dont know hw it got fixed.
  no audio in flv files with gom playerBy rocketman122 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jul 2011, 00:47
  Error Comment on GOM AND MPC Video player with MKVBy cutefix in forum Software PlayingReplies: 21Last Post: 2nd Apr 2009, 00:30
  new abbrev, GOM = GOM Player ?By lordsmurf in forum FeedbackReplies: 1Last Post: 1st Apr 2009, 16:00
  How much bandwidth is used in a typical 1 minute video?By chrisj in forum Newbie / General discussionsReplies: 10Last Post: 13th Mar 2009, 15:37
  Better playing performance out of GOM or VLC for HD video files?By quantass in forum Software PlayingReplies: 3Last Post: 24th Jun 2008, 18:08
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
