Every time I turn my laptop on, it stops on a screen that reads exactly:
Loading PBR 2...done
A disk read error occurred
Press Ctrl+Alt+Del to restart
I do that and it comes up again. I can't even get into safe mode. It worked fine yesterday! Can anyone help?
1. Did you leave a disc in the CD or DVD drive?
2. Not Good - Hard drive failure.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
Yes I did, but I've turned the computer on since then and taken the disc out.
You need to rebuild the MBR. Boot the computer from a win98 startup floppy or something similar, then at the command prompt type FDISK /MBR this should rebuild the MBR and allow it to boot. If this does not work, your hard drive could be dead or dying. Call Dell support.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
Actually I remember putting a disc in for a digital copy of the movie Juno bug. I had to download the new version of iTunes which I did, then it restarted my computer with that disc still in the drive, but it booted up fine, I put the digital copy on my computer, took the disc out and turned the computer off, then when I went to turn it on yesterday it started that crap.
boot into the computer's bios. note who manufactured your hard drive, i.e. seagate maxtor hitachi etc. go to the hard drive manufacturer's website and download their diagnostic software. run it.
I'm not sure what I'm looking for, all I see is:
System = Inspiron 6000
BIOS Version = A08 (07/22/2005)
System Tag = GHSCH81
Processor Type = Celeron M
Primary Hard Drive = 80GB HDD
Video Controller = Intel 915GM Graphics
Audio Controller = Sigmatel 9751
Salvaging CPU, RAM and Hard Disk from Laptop
By pchan in forum ComputerReplies: 6Last Post: 24th Nov 2011, 20:06 -
Datawrite disc wont read on pc and laptop
By lb77 in forum DVD RippingReplies: 3Last Post: 11th Nov 2009, 10:20 -
Play AVCHD disk on laptop
By aboveice in forum Authoring (DVD)Replies: 2Last Post: 1st Jul 2009, 04:34 -
Disk read error....
By rubberman in forum ComputerReplies: 12Last Post: 12th Feb 2008, 15:06 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 17th Jun 2007, 00:04
