  1. Hi guys... When i converted .asf to .mpeg using tmpegenc... the sound skips.. can someone help me with this or give me a link to fix this problem.. thanks.
  2. u should really tell us how u encoded the sound. u could probably extract the sound from the .asf file, convert the video, and then join it back with the audio and see if that works. or just try a dif. program than u use. make sure u encode ur audio as 44100 HZ, stream type: mpeg-1 audio Layer II, channel mode: stereo, bitrate: 224
    hope this helps alittle
  3. i chose System (video+audio) for the sound.. so it does it automatically..
    Is it best to extract the sound itself then fill it in later??
  4. Extract the sound using Virtualdub then save it as a WAV then use TMPGE to put it back together
