I have a number of JPG files (100+) that I want to convert into a movie... I also want to be able to adjust the rate between the images (ie 0.1sec, 0.33sec, 1sec, etc)... I would like to use a free-ware, share-ware, or low-cost option. any and all options are welcome
Patrick
Shuttle SH55-J2-BK-V1 w/4.00gb Ram, INTEL i3-550, 3.2ghz, WIN7 home premium 64bit
hauppauge 950q, 1600, 1250 -
There are few slideshow options. Microsoft have a free offering called Photostory which is surprisingly good except for one minor hitch - it only outputs WMV. Papa John has some high quality output templates for it so you can get DVD quality. It is flexible and reasonably clever. It does the Ken Burns things as well, if you need it.
You can also search the Tools section for slideshow and will find several other strong contenders.Read my blog here.
You can do that in virtualdub/virtualdubmod (free) as well. It should auto load the pictures if they are sequentially numbered (e.g. picture01.jpg, picture02.jpg...etc...)
Adjust the frame rate by using video=>frame rate
Use some sort of compression like XviD or DivX (video=>compression) -
OK, I have virtualdubmod and was able to create a movie... but how do I actually adjust the "speed"? I went into video/frame-rate and made several changes but none seemed to make any difference to the actual movie and the speed/frame/etc
You'll need a program like Gif Movie Gear which can change how long each frame plays. It's not free but IMO, it's well worth the $30 that it costs.
Here's a link the the trial download...
http://www.gamani.com/product_animated.htm
Blending Images(jpg) together
By Soixante in forum EditingReplies: 11Last Post: 24th Jan 2011, 19:28 -
Converting High res JPG File into HD Slide show/HD Movie
By dominic01 in forum Video ConversionReplies: 4Last Post: 13th Oct 2009, 02:58 -
converting bunch of images with sound to video
By dsikorsky in forum Video ConversionReplies: 0Last Post: 10th Aug 2009, 16:34 -
By bryankendall in forum Newbie / General discussionsReplies: 3Last Post: 29th Nov 2008, 16:13 -
How do I join JPG images to creat an AVI file
By forensic in forum EditingReplies: 9Last Post: 15th Mar 2008, 22:23
