Hi all.
I have downloaded a torrent and the file endings are 1080i DD5.1-CtrlHD.ts.par2
There are 6 parts to part 2. (i.e. .ts.01.par2 .ts.02.par2 etc....)
I cannot find a way to view them or to burn them on DVD.
Can someone please help.
Thank you.
PAR and PAR2 files are error correction files, not the actual movie files. Typically, you will have RAR files (which contain all of the actualy data) and then a matching set of PAR/PAR2 files, which can be used to correct missing or corrupt data within the RAR files.
http://www.slyck.com/ng.php?page=6Google is your Friend -
Thanks.....but.. there is no rar file.
These are the files I have:
Sharks - 1080i DD5.1-CtrlHD.ts
Sharks - 1080i DD5.1-CtrlHD.ts.par2
Sharks - 1080i DD5.1-CtrlHD.ts.vol01.PAR2
Sharks - 1080i DD5.1-CtrlHD.ts.vol01+02.PAR2
Sharks - 1080i DD5.1-CtrlHD.ts.vol03+04.PAR2
Sharks - 1080i DD5.1-CtrlHD.ts.vol07+07.PAR2
Sharks - 1080i DD5.1-CtrlHD.ts.vol14+12.PAR2
Sharks - 1080i DD5.1-CtrlHD.nfo
I managed to burn Sharks - 1080i DD5.1-CtrlHD.ts but not the others. -
What does it say in the nfo file?
The ts file should be the actual audio/video. The PAR2 files should only be used to fix the data file if it is corrupt. In other words, if the ts file plays fine and isn't corrupt or damaged, the PAR2 files aren't needed.Google is your Friend -
Wow, Sharkman. You quite possibly have downloaded the only torrent known to man that had PAR files with it. I'm stunned. I have NEVER, not once, downloaded any torrent of any kind with a PAR file.
You can download and install the free QuickPar program to use PAR files if you wish. I'd advise opening the Sharks - 1080i DD5.1-CtrlHD.ts.par2 with it just to check and be sure that your *.ts file is actually 100% accurate. QuickPar can repare the *.ts file is there are any errors by using the PAR files.
The *.nfo file is just some kind of text file with info about the ts file. -
This is what the nfo says.... (its chinese to me)
2005
A chilling underwater excursion dives into the depths to closely examine these
"ancient creatures of the ocean." Included is jaw-dropping footage of great
whites, hammerheads and whale sharks.
42mins
MPEG2Repair: Sharks.ts
Sequence Frame 32571(27-B) / Time 0:21:47 :
VideoWarning: Unexpected TFF/RFF flag change in previous GOP.
Sequence Frame 43832(0-I) / Time 0:29:30 :
Sequence Frame 58614(0-I) / Time 0:39:38 :
Info: End of MPEG2 sequence
Sequence Summary:
File Size Processed: 3.63 GB, Play Time: 00h:39m:38s
1920 x 1080, 29.97 fps (24.64 fps Telecine), 25.00 Mbps (12.33 Mbps Average).
Average Video Quality: 61.07 KB/Frame, 0.24 Bits/Pixel.
AC3 Audio: 3/2 Channels (L, C, R, SL, SR) + LFE, 48.0 kHz, 384 kbps.
Dialog Normalization: -27.0 dB, Center Mix Level: -3.0 dB, Surround Mix Level: -3.0 dB
0 of 58614 video frames found with errors.
0 of 74338 audio frames found with errors.
0 corrupted video bytes in file.
0.000000 seconds of video timestamp gaps.
0.000000 seconds of audio timestamp gaps.
End of Log -
So the movie file is Sharks.ts and it is 39 minutes long. Since you already stated you were able to burn the ts file, does it play and is it 39 minutes? If so, then you are done.
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 06:37 -
Burning .ts files onto a DVD for viewing on a DVD Player
By nazopo in forum Authoring (DVD)Replies: 2Last Post: 12th Oct 2010, 22:17 -
HELP!!!! me play my 23gb ts/par2 files!!!
By bobby999gib in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2009, 06:29 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 05:03 -
Is 1080i thru Component the same video quality as 1080i thru HDMI?
By Denvers Dawgs in forum DVB / IPTVReplies: 27Last Post: 13th Jul 2007, 17:25
