I recently converted to Vegas Pro 8...and I am wondering if there was any way to blur the background while keeping an object in the foreground (i.e a person) in focus? The effect I am going for is similar to the screenshot I attached (sorry, I could only find an flv version of the video).
Is there a plugin that would achieve the same effect?
Thanks in advance!
If it is pausing as a still, you could simply take that frame you are going to pause on, process it in photoshop or similar, then use this in the video at that point.
If you want to do it in Vegas, you would have to take two copies of the clip, mask the top copy so you can see through everything but the people (with soft edge to the mask), then blur the second clip so you see the blurring through the top clip.
Use Linear Blur on the bottom clip to get the motion effect. The default is pretty good.
Depending on the image you using, you might be able to get away with a simple cookie cutter. Add this to the top clip. Choose a rectangle, reduce the size to fit, then use the Feather setting to soften the edges until you are happy.Read my blog here.
yeah i was trying that the other nite and it seems to work alright..except i did a freeze frame, dragged that out, copied and did it...
masking is such a pain in the butt tho....i was hoping there was a plugin that i can use to save the work haha
hmmm i've never thought of using linear blur on the bottom clip....thanx! -
Originally Posted by mashimiriamRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Sony Vegas Pro 8
By Jules2 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Mar 2009, 19:59 -
Help With Sony Vegas Pro 8?
By Olivia Bishop in forum EditingReplies: 9Last Post: 2nd Mar 2009, 16:20 -
Sony Vegas 8 pro
By SNK in forum Video Streaming DownloadingReplies: 7Last Post: 20th Nov 2008, 08:09 -
Sony vegas 8 pro help
By jaycool1995 in forum EditingReplies: 2Last Post: 31st May 2008, 13:58 -
By jaycool1995 in forum EditingReplies: 5Last Post: 28th May 2008, 07:02
