I currently have DirecTV and will have it for two years since upgrading to a DirecTV plus DVR box. My set up is really simple. I have a Flat Screen Memorex tv with VHS/DVD combo. Then the DirecTV plus DVR box going in through YWR cable. I have been noticing lately macroblocks in the picture. Is there a way to stop that? Or is that normal?
Assuming that you are referring to when you are watching programing through the DirecTV box, then it may just be the result of the broadcasting (ie: you are seeing the results of the compression used for broadcasting, in which case there isn't anything you can do to fix it). I wouldn't expect bad cables or something simple to be the cause.
Google is your Friend -
You can fix it to some degree by upping service to the DirectTV MPeg4 HD service. Even then they compress more than broadcast.Originally Posted by BrokenOneRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 02:06 -
Sony Vegas - Picture-in-picture video creation
By jeanpave in forum EditingReplies: 5Last Post: 14th Dec 2011, 00:01 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 17:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 21:00
