Hi can someone tell me can you copy straight from a vcd disc to a blank disc to create another vcd if so whats the best program? and can you use most cdrs for this purpose.
Nero,CloneCD, CD-Mate.. any of these should work just fine...
Simply make an image of the VCD, and then burn the image. Or you could do "on-the-fly", but this is not reccommended if you have the reading and writing drives on teh same IDE chain.
Good luck.
Burning mixed/split mono VCDs
By ministry88 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 21st Jul 2011, 12:04 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52 -
I can not play some VCDs on my mechine. Can U help me ?
By wapw in forum Software PlayingReplies: 2Last Post: 21st Aug 2007, 11:46 -
extracting jpegs from vcds
By pk475 in forum Authoring (VCD/SVCD)Replies: 2Last Post: 9th Aug 2007, 10:38
