i have vistax86 bit i did windows updates which installed service pack 1 when i came to use svcd2dvd the program flashed on screen then went off i have set it run as admin but still won't work it was fine untill the windows update can someone please help
Can i suggest a reinstall of the program?
See: https://forum.videohelp.com/topic346055.html#1825650SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Xvid and Vista 64bit
By adalect in forum Video ConversionReplies: 11Last Post: 1st Aug 2009, 08:44 -
Vista 64bit compatible encoder
By tommcd64 in forum Video ConversionReplies: 2Last Post: 18th Feb 2008, 08:21 -
Windows Vista - 32bit or 64bit?
By HatchetMan in forum ComputerReplies: 29Last Post: 12th Jan 2008, 01:24 -
Vista Service Pack One Beta due soon.
By ahhaa in forum ComputerReplies: 4Last Post: 30th Aug 2007, 22:16 -
Is there any expected release date for a vista service pack?
By yoda313 in forum ComputerReplies: 10Last Post: 19th Jul 2007, 10:02
