I'm frustrated, can't get it in, doesn't work the way it's suppose to....you get the point! lol All joking aside here's the deal;
I'm not a complete n00b but I'm definitely no expert. I've used various freeware proggies like WinAVI and Diko etcetera and only lightly dabbled in others e.g. TMPEGnc. I have a bunch of x264 files that I want to convert to DVD to playback on my standalone. I've used WinAVI and seem to have okay results, but I was wondering if there is a better method using another piece of software perhaps that can do a better job quality wise? I'm using DL discs so I have more headroom. Any suggestions? If this is in the wrong section I apologies, please move accordingly. Thanks in advance.
Results 1 to 11 of 11
FAVC! Or maybe ConvertXtoDVD.
ANd I changed your subject. Please at least add something that describes the main problem. -
TYVM! I'm trying that now actually! Seems good, I was quite surprised how good WinAVI did, it was only DVD quality in the end, but I knew it would. When I watch HD content I just use my comp, but I want to take these over to my pops house and he has a bigger screen than mine and converted avi's look crappy. Hopefuly this will work better.
Keep the suggestions coming. THANKS ALL!
You need to use a bitrate calculator like this one ---> CLICK HERE
Thanks up until now I was guessing! lol Little off topic but I have regular avi files I want converted, what is the best method to convert let's say 4 or 5 350MB or so avi files to DVD without much quality loss? Thanks again! YOU GUYS ROCK!
Originally Posted by e_1337
Now you can go longer and still get acceptable quality but I would say that 2 1/2 hours would be about it ... if using Full D1 resolution (720x480 NTSC or 720x576 PAL).
If you want to go over 2 1/2 hours then I would use Half D1 resolution (352x480 NTSC or 352x576 PAL) and when using Half D1 resolution you can easily go 3 to 4 hours with 3 hours to 3 1/2 hours being the "sweet spot" as far as I am concerned.
Perhaps your overclock is unstable (4Ghz WC in your sig). What are your load temps at? What are you running your memory at (divider)?
Was there an error log for FAVC?
Do you have the 64-bit version of avisynth and FAVC installed? .net framework installed? -
Originally Posted by poisondeathray
No, it just "finished", but when I checked the folder it was about 25% complete. Yes to the last question, latest drivers (x64) etcetera. It's a moot point ATM, I used ConvertXtoDVD and WOW! lol I'm shocked at how easy and efficient it is!
Windows+ffmpeg+x264 = brightness(?) problems
By orangeboy70 in forum Video ConversionReplies: 8Last Post: 16th Feb 2011, 10:43 -
Anyone have a list of Sony HDD 1080P camcorders w/Night or SUper night shot
By peggypwr1 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 19th Dec 2010, 15:49 -
Bitrate vs Size Calculator for x264 for ripping DVD to x264 + AC3
By Bonie81 in forum DVD RippingReplies: 7Last Post: 5th Jul 2010, 18:24 -
AVI to x264 Problems
By DarthBuckets in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2008, 09:57 -
Problems with resizing x264 Mp4 videos.
By Fishd in forum ffmpegX general discussionReplies: 1Last Post: 5th Oct 2007, 08:36
