I have a Scientific Atlanta 4250 cable box from comcast, it has a firewire output but when i connect it to the firewire input of my DVD recorder, I can' see or record a signal, I can only record through the analog Svideo for an inferior image. Somebody help? :?
C.H.
It's possible your cable box isn't even outputting video over the firewire. Many cable and SAT boxes have the firewire and USB ports disabled.
Google is your Friend -
Hi & thanks.
Although comcast and scientific atlanta have assured me of the contrary, I suspect you are right.
C.H. -
According to US law (I have actually seen the legal reference, although the website that had it is no longer operation), it is illegal to disable the firewire output ports on a US sold cable box. I'm not kidding. That does not mean that it hasn't been done due to ignorance or stupidity on the part of Comcast.
Take a look here:
http://home.comcast.net/~exdeus/stbfirewire/
There are drivers here and a capture program (CapDVHS) for you to use in recording from your cable box firewire port to a PC. What you propose to do may not work at all. Recording is possible with these drivers, so if you install them and your PC records, then you just can't record firewire out from the cable box to a DVD recorder. Note that some programs (ie. HBO) ARE copy protected. This is legal and you will not be able to record these. If you are trying to record HBO this way, it will never work.
However, you should not be blocked from recording any local network show, so you can test with something from Fox or ABC or NBC, etc.
What firewire cable do I need?
By Jedi5 in forum MacReplies: 3Last Post: 7th Sep 2011, 16:17 -
Capturing HDTV with ethernet cable
By superdud1400 in forum Capturing and VCRReplies: 1Last Post: 17th Jun 2008, 23:31 -
Is This The Right Cable To Connect My Pc To HDTV?
By superstar in forum DVB / IPTVReplies: 18Last Post: 10th May 2008, 18:53 -
HDTV: Cable or Dish?
By fritzi93 in forum DVB / IPTVReplies: 27Last Post: 12th Dec 2007, 23:26 -
Standard cable on hdtv...
By bla4free in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jun 2007, 22:35
