Hi,
I recently acquired a set of DVD discs, which are 'NTSC' & 'Region 1'.
They play back fine on both of my region unlocked DVD players; although the players & TVs are UK PAL format.
That is, they play back fine until the final chapter on each disc. The discs seem to 'end' prematurely, the last few minutes of each disc seems inaccessable. I am pretty sure these are not bootleg discs, and it happens on 2 different players.
I have searched, and can't see this as being a common problem. Any ideas of what might be going on?
Thanks!
	Good idea!Can you see the ending on your PC, or if you rip them and run just the final VOBs ?
 The same thing happens when I play back on the PC, using PowerDVD. The last few minutes are 'missing'.
 Also, when ripping the VOBs to hard disk, the first 3 episodes are 45min long, but the last one only 40min, and sure enough, playing them on hard disk gives the same problem. The last 5 mins is either missing or unreadable
  Video Playback problem on high end PCBy hsn_kmr in forum Video Streaming DownloadingReplies: 0Last Post: 5th Oct 2011, 06:45
  low end quadro is 5 times faster than high end gaming cardBy deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 16:42
  Playback with MPCHC while still capturing stops at old end of fileBy suppa in forum Capturing and VCRReplies: 0Last Post: 30th Dec 2009, 15:11
  SVCD converted movie with choppy playback at the end on stand-alone playerBy supernano in forum Video ConversionReplies: 0Last Post: 27th Oct 2007, 11:10
  Low End Video Card w/ adapter vs. Low End DVD playerBy enter8 in forum Media Center PC / MediaCentersReplies: 6Last Post: 20th Aug 2007, 16:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
