Hello all,
I have tmpgenc dvd author 3 and I was trying to create a menu page showing all my clips
but it shows only the first imported clip, I tried different menus and settings but it only shows the first clip
Any help please how to fix this !
Thank you
My guess is you kept adding videos with the "add file" button on the right side of the screen. You need to add each video separately as a track by using the "add track" button on the left. In other words if you have 5 videos and you want to have 5 menu items then you will have 5 tracks.
author features from 2 discs w/ menus intact
By lockonx in forum Authoring (DVD)Replies: 2Last Post: 7th Jul 2011, 13:16 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
