I am looking at a security system that captures video as an MP4. Does anyone know if I would run into any issues trying to make a DVD from a MP4? Should I be looking for a security capture DVR that saves video as Mpeg2 instead?
Any help in understanding how this would work would be helpful.
Don
I am trying to avoid the step of converting the clips. Would DVD Studio Pro accept the MP4s and auto convert them during the authoring process?
Don -
Please post in the mac section if you would like "mac" answers. Moving you.
Avoid the converting? You must convert and convertxtodvd will convert and author to dvd. But as you have a mac it wont work...
DVDSP can convert your mp4 to mpeg2+audio but, there is still a transcoding.Originally Posted by donfife
mp4 is not natively compatible with DVDplayer (if you have a special DVDPlayer compatible with mp4, just burn a disc with the mp4 to ISO-9960, if you don't have, you must transode it to mpeg2, there are a lot of softs to do that)
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
I've seen Security systems that just use DVRs and record up to 8hrs
onto standard DVD-Rs. I'd advise going with that solution and cut out the middle man."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
usually, they stored video as mpeg1 (but you can do a DVD-video with it too
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 19:46 -
trouble with audio after appending a .jpg turned .mp4 to another .mp4
By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 09:55 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 04:53 -
loop mp4 or avi locally so will play on mp4 player - ?
By marinebc11 in forum Video ConversionReplies: 3Last Post: 3rd Oct 2010, 20:24 -
Converting to PS3 .mp4 with MP4 Converter on Mac
By The Sumerian in forum MacReplies: 2Last Post: 29th Dec 2008, 21:24
