  1. Hello, I am trying to author vob files with DD 5.1 sound, I made menus and chapters but when I want output the DVD for burn it...makes the demux fine, but then stops and says: failed, leaving me in the output folder lots of m2v files it seems cannot mux them. What is wrong??. Should I demux vob files first with another software and add them in the DVDStyler???.
    Thanks again,
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    DVDStyler uses mpgtx to demux mpg files. It isn't exactly the best program for this task. Doesn't handle errors all that well.
    Demux, then import elementary streams. If you have multiple vobs that make up one movie you might want to merge them first with vobmerge, or even DGMPGDec. DGMPGDec can load up the vobs in order and output demultiplexed m2v and ac3 files.
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
  3. I demultiplexed the vob files, imported elementary streams but DVDStyle still demultiplex them when is creating the vob files and same error.....I have no idea what causes this problem.
  4. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    How can you demultiplex something that already demultiplexed?
    Can you post the log?
  5. haha....silly me, I put ac3 files, but I selected MPEG instead m2v, now changed and seems to work!.
    Thanks so much!
