  1. Hello,
    I apologise in advance for the n00bness of this question, but Iīve been tinkering with the player preferences and I still havenīt figured out how to make VLC play a videoclip in loop.
    Is there any sub-menu I forgot to take a look at?
    Thanks.
    "They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
    When you play it forward, it installs windows."
    Jun 2007
    Norway
    You have to click on playlist next to the volume bar. There you can choose to shuffle or repeat one or all files in the playlist.
  3. Thank you, Xavier, I really appreciate it!
