I just baught a DVD player DVP3146, and... arght.... it doesnt play my DVDs due to "incorrect region" which is strange as i want to play DVDs from the same region as where i baught the DVD player.
Does any one know how to set the region? i want this player for Region 2 (please clear step by step explanation would be greatly appreciated!!).
thanks a lot
Julia
	I have checked the dvdhacks, it all sounds super easy:
 It mentions to: leave tray open (OK) to press setup on remote control (OK) then to go to "Preferences": (PROBLEM) i dont have the option "preferences"; i only have the options Language; Video; Audio; Rating; Misc
 Can someone help me, please?
	Two of the hacks in the links Midzuki provided don't require you to go into Preferences. Have you tried those?
 I only have the DVP642, not the 3146, but I'm assuming the behavior/menus isn't that far removed. Do you have a System - Menu button on your remote, and if you do - when you push it, does a window come up with 'Preference(s)' as an option?
						If cameras add ten pounds, why would people want to eat them? Do you have a System - Menu button on your remote, and if you do - when you push it, does a window come up with 'Preference(s)' as an option?
	thanks a lot for your help, the option of "open tray / press 98790" worked!
 i am all releaved and cant wait to watch all these movies,
 Thanks for your excellent and fast support!
  LG ht904ta dvd player regional free codeBy Mwilamj in forum DVD & Blu-ray PlayersReplies: 1Last Post: 7th Nov 2010, 01:49
  Regional Code Question - Insignia DVD player - can't play DVD I ordered..By LadyDriver22 in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 13:08
  LG HT963TA DVD regional code unlock?By Reasoner in forum DVD & Blu-ray PlayersReplies: 0Last Post: 24th Jan 2010, 21:54
  Country Code is not set but ...By LLavelle in forum Newbie / General discussionsReplies: 2Last Post: 8th Aug 2009, 18:12
  Durabrand ADB2737BDS changing regional code problemBy Natasha101 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Apr 2008, 14:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
