  1. i m having problem with converting to a mpeg file using TMPGEnc.
    i m using windows xp
    audio source :: wave file
    video soruce :: d2v file
    output suppose to be mpeg with both video and sound combined .. but the problem is on video comes out the sound isnt coming out at all .. u think it is related with xp and aspi layer to that sort of deal ..
    thanx
  2. Nope, that isn't releated to ASPI, maybe to XP, but defenetly not ASPI problem, which version of TMPGEnc are you using ? and was TMPGEnc giving you any problems opening the WAV or D2V ? can you play the WAV on it's own ?
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Hi,
    I have simular problem. Trying to copy "The Green Mile" everything looks good but when I try to test the audio file w/TMPGEnc it says file corrupted or wrong format. The vidio part seems fine , but no audio. I think the problem is with Smartripper or DVD2avi. Must be Tom Hanks movies, had a hell of a time with "Castaway" also. Funny thing, it shows the audio file as 2.2gig but nothing seems to be there. I tried this on 2 machines w/same results. .... harrymj3
  4. i m using beta version 12i..
    i used audio player to test out if something was wrong with the wave file but it sounded good .. its just when its put under tmpengc its not encoding in right manner i mean the video comes out good quality and all but just audio isnt coming out help would be appreciated
  5. Well, I don't know if anyone ever tried it, but, you could try encoding the D2V on it's own to create a MPV (M1V) file, and then encode the Audio into MP2 on it's own as well, and then just mutliplex the two files.
    Best Regards,
    Sefy Levy,
  6. OK Guys,tell you what I did. I was getting no sound from "The Green Mile".Tried it in 4 machines with Cladmec, Clad2.0 and smartripper. No sound. So finally by watching DV2AVI I saw the audio stop and start again in the middle of the movie. I reripped w/CLAD 2.0 had 8 vob's, noticed 1,2,3,5,6,7 are very large and 4 and 8 are small. So I encoded the first 4 vob w/DVD2AVI into one file and the last 4 vob into another file.
    Then I ran the two new files thru TMPGEenc seperately using SeVCD with the sound at 96k. The first half is 99 min 836mb. The second half is 94 min 776mb. Used a 90 min cd for first half and 80 min cd for second half. Used VCDeasy 1.05 to burn. How about that, a 3 hr 8 min movie on 2 cd's. Plays nice on my Pioneer 603 and it even has good sound. Have fun! .......... Harrymj3
    Thank's Sefy for the help and the great templates.
  7. You are most welcomed harrymj3, glad to hear you enjoy the use of the Templates!
    Best Regards,
    Sefy Levy,
