If you have no audio (or don't care about audio sync) you can use the top portion of the frame rate dialog. Set the frame rate to 29.97 fps. This will simply slow the playback down. You will see all the frames of the original video, just a tiny bit slower. Audio will slowly drift out of sync. After an hour the audio will be 3.6 seconds ahead of the video.
If you need to maintain audio sync you should use the center portion of the dialog, the "Convert to FPS []" option. To convert 30 fps to 29.97 fps 1 frame out of every 1001 will be dropped. This can cause a visible jerk if that dropped frame is in the middle of a smooth motion. But the audio will remain in sync.
Results 31 to 32 of 32
Thank you, I’ve chosen the second of the two options because it’s actually a kind of music video and I need to maintain it in sync. There is one visible jerk on a smooth motion. But that’s Ok, not a big deal. I can’t check the video on a HDTV now, but I assume it’s fine (looks Ok on non-HD TV). Looks like I’m all set now, thank you for help! That was too much problems for just 4 min of amateur video, wasn’t it?
At least for me...
Here the video: http://www.youtube.com/watch?v=DC6bECuf-Ss
Change Aspect Ratio
By wulf109 in forum DVD RippingReplies: 1Last Post: 7th Feb 2011, 19:12 -
MiniDV to DVD to .wmv Aspect Ratio Playback Problems
By 2therock in forum Video ConversionReplies: 15Last Post: 12th Jul 2010, 13:17 -
Aspect Ratio Change
By VicSedition in forum Video ConversionReplies: 9Last Post: 17th Feb 2010, 12:01 -
Whats going on? miniDV, software, aspect ratio, dimensions
By vid83 in forum Newbie / General discussionsReplies: 2Last Post: 12th Dec 2008, 08:25 -
How to change aspect ratio?
By crt in forum Video ConversionReplies: 2Last Post: 9th Oct 2008, 11:49
