Hi,
I hope someone can help me with some tips
I have an HD mkv movie that I'd like to playback with a digital media player
that unfortunately does not support this file format or H.264/X.264 compressions.
Therefore I see the only option as to convert the MKV to uncompressed AVI
in order to keep the HD resolution.
How can I acchieve this?
Thankfull for any and all suggestions.
TheLarch
If your machine specs are right, you don't have a system capable of playing back that amount of data.
I would use the haali splitter and ffdshow, avisynth, and if possible, encode it to high bitrate mpeg-2. 25 mbps should take up around 13 GB/hr and be almost playable on your system. Not a lot of mpeg encoders can do this yet though.
If you want uncompressed, use avisynth to load it into virtualdub and save it as uncompressed from there using Fast Recompress.Read my blog here.
What is uncompressed AVI?
By andrewjameshoward in forum Capturing and VCRReplies: 35Last Post: 2nd Nov 2012, 08:56 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
H264 (MKV) to Uncompressed RGB (AVI)
By ta2 in forum Video ConversionReplies: 2Last Post: 22nd Feb 2008, 12:00
