I have a movie, in VIDEO_TS format, it already has selectable subtitles in there. I want to replace it with my own subtitle file, I have it in both .srt and .sup files, I can't find a good tutorial for how to simply replace it without taking it apart and putting it back together. I'd like to just open the one .ifo or .vob file and replace/save, but I don't think that's possible.
My second option is to just rip it to m2v/ac3/sup, then put it back together in a NEW VIDEO_TS folder. I have done this already, and although the subtitles don't work MPC, they work in VLC Media Player, hope they work when I burn it to a DVD and try to play it on my DVD player. But I found out the subtitles, all of them, every line, is a second or two off. A little ahead of the actual voices. Does anyone know how I can fix this easily, without going and redoing the timestamps to all 600+ lines in the .srt file?
Thanks.
Hi-
That's because there is no such thing. The reason there is no such thing is because it's not possible. You'll have to take apart the DVD. As perhaps you know, there are some stickies at the top of the Subtitles Forum that explain the process. I might suggest Method 2 of Baldrick's guide:I can't find a good tutorial for how to simply replace it without taking it apart and putting it back together.
https://forum.videohelp.com/topic338721.html
I don't know the method you followed, but it's possible to adjust the delay of a SUP file before muxing using SubtitleCreator (Tools->Manipulate SUP or VobSub), or the sub delay in the finished DVD by using DVDSubEdit. Both methods can adjust the delay for all the subs. You won't have to do it for the 600 individual lines of dialog. If you prefer to do it to the SRT file, SubtitleCreator can do that also. Open the SRT and then go into the Synchronize Tab.But I found out the subtitles, all of them, every line, is a second or two off.
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
Video and subtitle/sound sync problems in SubtitleCreator
By ditz in forum SubtitleReplies: 2Last Post: 20th May 2011, 04:12 -
adding watermark as a subtitle
By zammil in forum SubtitleReplies: 8Last Post: 20th Nov 2010, 00:45 -
adding subtitle
By Rezadarius in forum ffmpegX general discussionReplies: 1Last Post: 9th Aug 2008, 04:45 -
Adding a subtitle for a DVDR
By rotchild in forum SubtitleReplies: 5Last Post: 28th Jan 2008, 11:07
