Hi
I have a 10 hours TOM & Jerry DVD Movie. I have ripped them using Decryp HD. However when i use Shrink to spilt them into 2 DVD disc i encounter something i dont like. The original disc has 10 movies each with 16 chapter. After i split them to 2 disc ...e,g. whenever i want to watch the 3rd movies chapter 11 .. i have to first go to Moive 1/10 Chapter 16/16.. enter next to go to Moive 2/10 Chapter 16/16........and then next to go to Moive 3/10 Chapter 11/16... then i can watch this chapter ....
Now .. i would like either :
1) to have the disc consist of 80 chapters for 1st disc ..so that i can go to any chapter easily
or
2) to have a menu for the 5 moives to select in the begining .. then choose the chapter..... but if i use Shrink then all the menu would be gone
Is there any easy guide out there to do what i wants . I would like to use ONLY freeware to perform the task.
It isn't exactly long-term "freeware", but you can download a 30-day free trial of the programs CloneDVD2 and AnyDVD (see VideoHelp software section for links). This is the most reliable software suite for splitting one DVD across two DVDs while preserving the original menus.
Note it is sometimes not possible to COMPLETELY preserve all menu functions when you split a multi-episode TV or cartoon DVD across two discs: you will often lose the "play all" function and sometimes other minor navigation options, because these depend on having all the episodes on ONE disc. When you split across two or more discs you "break" the auto-play connection between all the episodes, and are then usually limited to manually selecting them from the menu on the two backup discs. CloneDVD will of course preserve the episode selection screens and any bonus material navigation and whatever other features that don't rely on having all the episodes on one disc.
DVD to MKV- Change audio, leave Video intact.
By cal_tony in forum Video ConversionReplies: 2Last Post: 1st Jun 2011, 11:43 -
MKV to dvd while keeping the dts audio intact
By Loonatik in forum Authoring (DVD)Replies: 13Last Post: 30th Mar 2010, 10:41 -
Converting a DVD to AVI with all menus intact
By beatsntoons in forum Newbie / General discussionsReplies: 4Last Post: 17th Dec 2009, 14:39 -
How to make DVD recorder disk playable on TV with all scenes intact?
By Stabes in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2007, 14:02 -
Xvid to DVD with aspect ratio intact?
By StratPlaya in forum Video ConversionReplies: 12Last Post: 5th Jul 2007, 13:02
