Can I watch my 50i HDV on a US HD TV? (I think it may be this damn confusing Panasonic HD TV - I can't see anything - have it on component jack.)
Results 1 to 9 of 9
Only on a few US TVs. Most will only display 60Hz content (even HD).
Cheers,
David. -
Some manufacturers block 50Hz to discourage export. Others don't.
http://www.kiva.org/about -
I'm sorry, Hz? The framerate is a reflection of frequency? Interesting. OK. Anyway, the manual says power source 60Hz, and that it displays 60i and 60p. (Should have checked the manual, but videohelp is where I go automatically.)
Now I should have no problem capturing 50i HDV in a Vegas 6 50i HDV project, right? First try and Vegas does not see the camera. Thoughts? Best and thanks, -
You were talking about a TV right? I was assuming you hooked the camcorder directly to the TV using analog component or HDMI. Some US model TV sets accept 50 fps video others don't. Take your camcorder down to Best Buy and see which one's work.Originally Posted by kippard
Vegas works with 50i fine. Version 8 is better for HDV especially capture. You can also capture with HDVsplit and then import to Vegas.
Which camcorder and TV models are you using?Recommends: Kiva.org - Loans that change lives.
Yes, ed, a TV: the Panasonic TH-42PX75U. Manual says 60i and 60p - no mention of 50i. My camera is the HVR-Z1U.
And, yeah, it's like I can have a 50i HDV project in Vegas 6 but can't capture it. I'll try HDVsplit. Although, if I'm using Aspect HD 24p conversion, I think I have to capture with the Aspect HD conversion utility, right? Haven't got that installed yet - is that workable and does it work from Premiere Pro (I have 1.5). -
I think Aspect HD directly captures HDV. Check the specs. Neo certainly does.Originally Posted by kippardRecommends: Kiva.org - Loans that change lives.
HV40: Record in HDV(PF24) vs HDV(24F)
By videobread in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 23rd Dec 2011, 20:44 -
HDV (50i) to Pal Anamorphic (50i) problems with Avisynth (sample included)
By VooD in forum Video ConversionReplies: 15Last Post: 1st Aug 2008, 07:22 -
50i to 25p
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 11th Jun 2008, 06:34 -
Magic Bullet for 50i HDV
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Mar 2008, 04:34 -
HDV 50i or 25p, which is best for future proofing??
By chris langham in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Jul 2007, 03:47
