I've been trying to convert the first season of Frasier to iPod format. From what I have read the show is filmed on 35mm. But the DVD is stored as an Telecined NTSC 29.97fps and everytime I try to convert it, it is serverly interlaced with many artifacts. I was wondering what the best way would be to get the back to the original film frames.
Thanks,
James S
Have you solved this?
If not, what software have you tried? I would try Fairuse Wizard, Xvid4PSP, Staxrip, handbrake and see if it works better.
(How to) Inverse Telecine
By Cherbette in forum RestorationReplies: 16Last Post: 17th Nov 2011, 13:24 -
Inverse Telecine Anime (Death Note)
By Corpsecreate in forum Video ConversionReplies: 16Last Post: 7th Oct 2011, 02:55 -
AviSynth with VirtualDubMod - Inverse Telecine advice needed
By spicediver10191 in forum Video ConversionReplies: 5Last Post: 7th Dec 2010, 01:29 -
PAL Inverse Telecine?
By Anakin in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 07:34 -
Inverse Telecine, IVTC
By kitty in forum GlossaryReplies: 1Last Post: 10th Jan 2008, 21:40
