    Feb 2006
    Brazil
    I have authored a DVD using GFD. DVD has 7 mpg movies. For each of them I've put a button on menu and there is also a play all button. No chapters. DVD has behaves differently in different player. No. 1- menu is ok. No. 2 menu jumps to video 1 "automatically", plays video 1 goes back to menu. The only way to play other videos is jumping through next track key. No. 3 menu wors ok, but after playing video it doesn't come back to menu. Any hints? Thanks.
  2. Hints? No, not really. Are you using the MuxMan or dvdauthor engine?
    Probably MuxMan is more 'compatible' with different players as it follows the DVD specs more strict.
    Concerning: ...jumps to video 1 "automatically"... I have a similar 'behavior' sometimes with bad media.
    Feb 2006
    Brazil
    What kind of video files does muxman accept? It does not accept mpg files used with dvdauthor. Thanks.
  4. Only elementary streams in DVD compliant resolution. Just demultiplex the mpg files and muxman should accept them.
