hi everyone im going mad and in need of some advice, i have a dvd that i want to convert to avi then i want to cut out a certain scene but i have tried using win avi to convert the vob file to avi but it just crashes if someone could help me out with the best programs for the job id be so greatfull im going mad lol
many thanks
Results 1 to 14 of 14
Did you want just to retain the scene, or the whole DVD minus the scene?
autogk is an easy way to go DVD=>.avi
Then you can open up your .avi in virtualdub or avidemux, use direct stream copy for audio & video, and the mark in/mark out function to denote the cut areas (make sure you use keyframes) and delete
If you just wanted the small scene, it would be easier to cut it out with mpg2cut2, then encode that small scene with either virtualdub or avidemux -
all i want is to cut out i scene from the whole dvd which is about 4mins long its a music dvd i made and i just want one of the videos sorry 4 sounding confusing
dvdshrink. use it in reauthor mode. once you drag the main movie to the left pane use the clip function |<-->| to select the portion you want and shrink will cut it out and make it into a video_ts folder with vobs. from there you can convert it to mpeg2 or anything else you want.
superJT, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
sorry about that mate i no 4 future now
still havin a little prob i have got the avi file now using autogk and watched it and its all in sync, i then opened virtual dubmod opened the avi file and cut out the scene i wanted and the audio was well out of sync did i miss something out?
i tried something else i dloaded the normal virtual dub not the mod version opened the avi file i then get a message saying VBR audio detected may encounter sync errors when when proccessing audio in direct stream copy, so i cut out the scene and used full prossessing mode for video and audio and this time it was in sync the only prob is that the file came out at 4gb!! why so big when i prossessed it direct stream it came out at 35mb?
Beacuse in full processing mode, you have to select output video and audio codec. What you've done was to save out as uncompressed.
But if I was you, I'd back up to the AutoGK stage, and make sure you select CBR audio for your DVD to AVI conversion. That way, you can cut and save out in Direct Stream mode without any sync problems, and don't have to reencode yet again (as you have to do when saving out using Full processing) and reduce quality further.
/Mats -
ok i give that ago the audio track listed is vbr mp3 i take it u mean change the audio setting in the advanced menu to cbr yeah?
Yes. VBR audio in AVI is always bad news, and should be avoided like the plague.
/Mats -
You can use VirtualDUB MOD, for MPEG files. Open the VOB file containing the scene you want and use VirtualDUB to cut everything before and after the scene.
You will need to compress the MPEG video source to something else, e.g. xvid, and the audio to CBR MP3. You could leave the audio untouched, i.e. run audio in direct stream copy, it's MPEG audio anyhow.The more I learn, the more I come to realize how little it is I know. -
im now trying with dvd shrink i have set the frame i want 2 re author but cant find any button to get the whole thing going lol im going mad
lol im so dum i done it finally, ripped the scene with dvd shrink the autogk to get the avi file from the vob job done, its so easy when u no how aint it
Yeah, innit?Originally Posted by superJT
/Mats
Edit a movie (avi), cut some scene but KEEP subtitle in synq! HOW TO??
By GiBsom in forum EditingReplies: 5Last Post: 18th Dec 2013, 19:58 -
cut scene out of .vob using SonyArchitect 5
By stevene in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 04:58 -
How to Cut a scene using Avidemux 2.4
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2009, 17:08 -
How can i cut out a scene from a wmv?
By denadel in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 09:25 -
cut a scene using VirtualDub
By exon in forum EditingReplies: 3Last Post: 19th Jul 2007, 17:05
