Hi everyone.... I have a dilemma & I would be sooooo grateful for ANY help if possible. I have a ton of AVI ,ASF & WMV videos & I was using Pinnacle to create a DVD with a menu. I am having trouble figuring out how to make the DVD length over 2hrs long. I need to burn all my AVI files to DVDs but, they MUST be somewhere between 2-3 hours long each. I know I must not be compressing them properly. (And they must have a menu).The quality of them does not need to be excellent... Thanks in advance for any info anyone may have..
Why do you need menus?
Just get a DVD player that directly plays divx/xvid off a data DVD. wmv takes a more expensive player currently but not in the future.
Otherwise you need to recode to MPeg2 with quality loss.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I need menus because I'm trying to make my own movies with working chapters that you can skip ahead to if needed...
Some DVD authoring programs decide to "help" you by not allowing you to put more than 2 hours of video on a single DVD. They just decide for you that the quality of allowing more video isn't a good idea. I have never used Pinnacle, so I can't offer any suggestions on whether or not you can possibly override this, but probably you cannot.
ConvertXtoDVD is supposed to be easy to use and it can create menus. You should not have a problem putting 2-3 hours of video on a DVD using it. -
A freeware alternative to convertxtodvd is favc
Both very easy to use, and do the encoding, authoring, and include simple menus
2 Hour Long File Conversion ffmpeg
By wsander9 in forum ffmpegX general discussionReplies: 3Last Post: 8th Oct 2011, 01:23 -
why can't I make dvd w several half hour shows dvd architect/sonic-
By rr1 in forum Newbie / General discussionsReplies: 5Last Post: 14th May 2011, 13:28 -
How long does it take to make a DVD to AVI?
By iamkatpeeler in forum Newbie / General discussionsReplies: 6Last Post: 24th Jan 2009, 02:08 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 15:18 -
4 half hour eps on one dvd?
By motleycool in forum Newbie / General discussionsReplies: 4Last Post: 4th Jun 2007, 00:18
