Hi,
I have a whole series of tv episodes that were encoded with the wrong format i.e. 16:9 instead of 4:3, so people look fatter than they should.
Of course I can easily change the aspect ratio in VLC to 4:3 but If I wanted to make a permanent correction, what would be the method with the least loss of quality?Originally Posted by [url=https://www.videohelp.com/tools/GSpot
Results 1 to 16 of 16
Use MPEG4Modifier to change the display aspect ratio. Some players will igore the AR flag though. Otherwise you'll have to resize to 448x336 and renencode.
You can change the aspect ratio to 4:3 using MPEG4 Modifier but some players will ignore it. So if you would like all players to play it then you must reconvert with for example avi recomp.
Or you could resize to 576x432 and reencode. Or any 4:3 ratio frame size you want.
Thank you Jagabo and Baldrick for your replies.
Will MPEG4Modifier generate a loss in quality?
If I had to re-encode, would converting to DVD give me better results? -
When I tried to open MPEG4Modifier.exe, I received the following message.
yes, I have .Net Framework 2.0 but apparently there is a problem with it.
I thought that maybe it was corrupted and tried to repair according to the instructions from Microsoft
But it failed with this messsage
I left a message in the Microsoft forum to see what the problem is -
Your computer details say xp, but that looks very "vista-ish"? or is that just a "skin"?
Might that be the problem? -
Did MPEG4Modifier crash on startup or after you started working with the file?
MPEG4Modifier crashed on start up as soon as I tried to open the MPEG4Modifier.exe
That sounds like a .net framework problem then. I don't know where you go from here...
Just a thought, I haven't tried it myself: Use VirtualDub (if you like, in connection with Cut Assistant) to cut off the first frame of your video. In VirtualDub, use SmartRendering. As Codec for SmartRendering, use FFDShow. Config FFDShow Encoder to the same FourCC as in your original Movie and use the settings for AspectRatio in FFDSHow to Correct your A/R in the avi.
This could have the following effect: YirtualDub will re-encode the first couple of frames up to the next keyframe, using the settings of FFDShow. So you could set a new A/R for the AVI. Again, this is just a thought... -
Originally Posted by BiggerJim
I have a suggestion if this is just for PC playback:
Wrap your .avi file in an .mkv container with mkvmergegui. There is no need to extract raw streams, it should work fine already in an .avi container.
Select the video stream, and under the "format specific options" tab, there is a drop down menu for aspect ratio. In your case, select 4/3
This was successful for me: both in MPC played the file correctly, and mediainfo displayed DAR 4/3
There is no re-encoding, just "repackaging" of the video file and it takes only a few seconds. In fact, you can just "undo" the process with mkvmergegui. So this is "permanent" as long as you leave it in the .mkv, but has the option of transforming the video at a later date, without destroying the original quality.
Cheers
Aspect ratio and conversion issues with an AVI file.
By destino in forum Newbie / General discussionsReplies: 3Last Post: 13th Mar 2012, 06:30 -
how to add the correct aspect ratio flag in an avi file?
By graysky in forum DVD RippingReplies: 15Last Post: 23rd Nov 2007, 04:23 -
one more question about avi file's pixel aspect ratio
By compusic in forum Software PlayingReplies: 2Last Post: 25th Jul 2007, 02:43 -
Correcting VCD aspect ratio?
By gastrof in forum Video ConversionReplies: 4Last Post: 30th May 2007, 14:43 -
Change/Set aspect ratio in AVI file
By cheerful in forum Newbie / General discussionsReplies: 9Last Post: 7th May 2007, 17:28
