I get cyberlink power2go burning software to burn a movie into a DVD+RW. However , halfway burning I cancel it as I wanna to do something else. I have been doing so for 5 disc and now my PC DVD drive is not able to read the disc again. The drive just keeps spinning the disc without stopping. How can I use the disc again?
I remember I once used NERO to stop the burning and the disc is usable again.
Not the sort of thing you should do ... if the disc's are now just spinning, then trash them, there shot.
Only way to fix it is to erase the disc, but if your drive cannot read it, I think you are out of luck.
Whenever something like this happens to me, I just keep trying different applications that have a disc erase function. You can also try formatting the disc with Nero InCD or something...even if you don't want it formatted it may fix whatever problem there is with the disc then let you use it again. Eventually you will find something that works.
Hello friends, newbie here...i also want to share my problem... i m using sony dvd cam, when i bought, the dealer gave me 2 free dvd-rw,, it states there can reusing til 1000x, but js used it 5x, both already spoil,, js can record half way then stuck, then i bought the other brand from Taiwan, its ok, but disturb by' sony disc recommended :wink: ' on screen in the beginning. then i bought the FAKE sony dvd-rw, yea,, it work, i had already 15x reused n still very good condition. anybody can comment, something wrong with original dvd-rw or i don't know how to use or take care of it?
One darn thing after another... Incoming! Roxio download refuses to cancel
By ahhaa in forum ComputerReplies: 3Last Post: 31st Oct 2009, 07:45 -
Where is the Stop or Cancel Button in VOB2MPG ver. 3?
By SuperFist in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 3rd Jun 2009, 05:27 -
DVD recorder that will read movie files from ex hard drive?
By siratfus in forum DVD & Blu-ray RecordersReplies: 9Last Post: 3rd Oct 2008, 15:26 -
Losing audio halfway through DVD slideshow...
By my_2_princesses in forum Authoring (DVD)Replies: 2Last Post: 22nd Apr 2008, 17:42 -
DVD+R Doesn't play after halfway through
By cfresh13 in forum DVD RippingReplies: 9Last Post: 21st Mar 2008, 20:28
