Here's the Avi's specs:
File Size (in bytes): 734,027,776
Duration: 1:25:00
Subtype: OpenDML (AVI v2.0),
Video Codec Name: XviD 1.1.2 Final
Width x Height (pixels): 640 x 272 =[2.353:1]
Video Bitrate: 952
Bits/Pixel: 0.219
Frames Per Second: 25.000 fps
Compatibility: B-VOP , ,
Audio Codec: 0x0055 MPEG-1 Layer 3
Audio Bitrate: 192
Audio Channels: 2
Interleave/Preload (ms): 80/504
I converted it to dvd using Avi2dvd, and everything worked well, but (of course, there's always a "but" with a problem), it turned out stretched vertically.
I went back to the original avi to see if maybe there was an issue there, but when opened with VirtualDub it was fine, the image was the way it is meant to be. I've gone back to the converted files and can't seem to get it "fixed". I've looked into it with PgcEdit (as an experiment) but nothing, and have looked into it with DvdPatcher (also an experiment) but didn't seem to have any luck.
I'm thinking there was an issue along the way with Avi2dvd, likely something I did, but am trying to figure it out. Any guesses where things got mixed up? More info needed?
Thanks in advance!
Ben
Results 1 to 1 of 1
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
AVI to DVD with soft subtitle and menu with AVI2DVD
By kschang in forum User guidesReplies: 95Last Post: 7th Feb 2011, 16:55 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 09:23 -
Trying to convert AVI to DVD using AVI2DVD
By justmehere in forum Video ConversionReplies: 2Last Post: 22nd Jan 2009, 09:28 -
a good tool for converting avi or divx to the dvd vob format?
By extent in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2009, 13:37
