I have had my HDTV for over a year now and I turned my xbox on a few days ago and it just displayed a solid pink screen. My Ps3 connected through the Hdmi is just fine. But anytime I connect anyting to my component inputs. I get the pink screen i was wondering if there is anyway to fix this. Sometimes the screen goes pink from the Hdmi too but it goes away. I really got good picture though my component too.
This is my setup.
Hdtv (Westinghouse)
Xbox 360 though component ypbpr
playstation 3 through Hdmi
Either you have a bad cable or you have the G,B,R plugs in the wrong connectors at the TV. Green carries the luminance Y signal (monochrome).
Or you haven't set Y,Pb,Pr in the XBOX menus.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
No, the xbox was hooked up the whole time and working perfectly, picture was excellent. This problem only happened a few days ago. Everything was fine until a few days ago, when i turned it on and the screen was solid pink, there is sound though.Originally Posted by edDV
Assuming you haven't already, try connecting the PS3 using the component cables (new/different cables). If you still have a pink picture, then you will need to get the TV serviced/repaired.
Google is your Friend -
The fact that you say it goes pink on HDMI "Sometimes the screen goes pink from the Hdmi too but it goes away." leads me to think the TV set needs servicing.
DVI to Component to AverTV HD Express- YPbPr works on HDTV but not AverTV
By asperi in forum Capturing and VCRReplies: 1Last Post: 9th Jan 2012, 10:22 -
Laptop Pink screen of doom! Please help!
By hellfire45 in forum ComputerReplies: 3Last Post: 25th Dec 2010, 13:24 -
Green and pink static on HDTV after Blu Ray install
By Jake33383 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 3rd May 2010, 16:55 -
When certain subs appear, the whole screen goes pink
By oldjoe911 in forum SubtitleReplies: 1Last Post: 9th Sep 2008, 18:14 -
Neon Hot Pink Problem with HDTV
By SLB131 in forum DVB / IPTVReplies: 4Last Post: 4th Sep 2008, 13:49
