it's in the settings of your graphic card but i doubt it's the real problem, anyway try it (i use 1024x768 personnally).
I got an Ati radeon and i have access to the settings when i click on the icon "Ati/catalyst center" at the left/bottom corner of my screen.*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
hmm i just keep getting the same error and i have all programs closed when i use it
Right click on your desktop, select Properties, Settings tab, Display resolution, move the slider to the left to reduce the resolution.
Ah, just noticed you're running Vista. No idea how you reduce the resolution. It might be the same but I somehow doubt it.....
I'm having a problem deciding what Capture Card to buy
By Mufc in forum Newbie / General discussionsReplies: 3Last Post: 10th Apr 2010, 10:10 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
Capture Card and Virtualdub Problem
By TV107 in forum Capturing and VCRReplies: 3Last Post: 29th Nov 2008, 18:35 -
No sound problem - internal tv capture card
By planetx in forum Capturing and VCRReplies: 1Last Post: 5th May 2008, 05:38 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
