I got a MKV file, that I can play with VLC player.
I also installed the lazyman MKV codec.
I opened up TMPGenc and try to convert it, but TMPGenc won't do it. I went to select direct show as proprity 0 in TMPGenc, and it still can't figure out it out.
What should I do, to get the MKV file convert to DVD mpeg2 ?
Will it read the subtitles from inside the mkv container - no. Use MKVExtract to get them out first, so you can load them into FAVC.
Read my blog here.
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Convert HD MKV or AVCHD to HD MPEG2/AC3, with subtitle support?
By elsinga in forum Video ConversionReplies: 14Last Post: 25th Dec 2010, 13:56 -
Convert MKV to Mpeg2 with Procoder
By 557953 in forum Video ConversionReplies: 0Last Post: 15th Jul 2010, 17:41 -
Best way to convert MKV files to MPEG2
By carlmart in forum Video ConversionReplies: 47Last Post: 6th Feb 2009, 00:08
