I recently bought a Sony DCR-SR220 DV Camera. It has been great and the video has been super clear. When I use the very basic video editor that Sony provides (Let's Enjoy Video) the DVD is very clear. The mpeg-2 files also appear extremely clear when I just bring them up using Windows Media Player.
I tried using my Adobe Premiere Elements 3 to edit and burn the MPEG-2 files, but the video becomes grainy. I also have tried Pinnacle 11, which I took back because it also lost quality and became grainier after imported. I bought Vegas Movie Studio 8 Platinum today, thinking that since the basic Sony editor that came with the camera worked this might work as well. However, the quality also degrades and becomes grainier when I import into the Vegas editor.
Does anyone have any suggestions for me. I am exteremely frustrated and not sure what to do.
Any help would be most appreciated!
Thanks.
-Mike
try viewing your video with gspot or the like
try viewing it in vlc media player
try removing and reinstalling your mpeg2 codec and or display drivers
sounds like something went wonky -
This isn't a mini-DV camera, so it records using the mpeg-2 codec. Mpeg-2 is a poor codec for editing, especially in Premiere or Vegas, as neither are designed to edit mpeg-2 natively. This means any editing you do with force a complete re-encode, and a drop in quality. Womble would be a better choice, as it allows you the ability to edit mpeg-2 on a traditional timeline with minimal re-encoding.
Other factors include the original bitrate. The camera has three levels of quality - HQ @ 9 mbps (approx 75 minutes to a DVD), SD @ 6 mbps, and LP @ 3 mbps. All 3 are at full D1 resolution, so LP will be low quality to begin with, and only get worse. SD will be OK for talking heads, but suffer badly if the camera or subjects move around. HQ is the only mode to come close in quality to standard DV.
What mode are you using ?
The best choice of all (aside from getting a better camera) would be to buy the Mainconcept mpeg-2 editing plug for Adobe Elements. This will allow you to edit the files as native mpeg-2 video in elements, making faster and reducing quality loss substantially.Read my blog here.
Thanks for the quick reply Gunslinger. I have shot all of my video in the HQ mode.
Would you say the Vegas is now a wash? It seems crazy to me that Sony wouldn't develop a editing software that is compatible with their cameras?
Is there any reason why the cheap software that Sony sent me did not degrade the video but Vegas did? I can't understand it.
I will also try the Main concept plug for Premiere elements and also try Womble, but any help in getting Vegas to work would be great (since I just bought it)
I truly appreciate everyone's expertise.
Thanks!
-Mike -
Sony haven't developed any of the software form the ground up. They have bought what they needed, and taken it from there. Vegas was never designed for consumer DVD or mpeg cameras. It has always worked best with DV. It can work with the others, but at a cost. The freebie that Sony threw in will be dedicated mpeg-2 editing software. It works natively with the compressed footage, but is limited in most other areas.
Vegas should be able to load the footage without degrading, and allow you to edit it. It should also be able to output mpeg-2 without degrading the image noticeably, so long as you use the correct settings. To maintain the quality you have now, you would have to keep the running time do 70 minutes or so, and use as close a bitrate to the original as you can. If, after doing this, you find you have major quality differences, then you have other problems.Read my blog here.
Imported video goes narrow---Nero 8
By will7370 in forum EditingReplies: 2Last Post: 17th Aug 2011, 23:44 -
Imported DV avi from JVC, video and audio too fast
By AdamskiCox in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Oct 2010, 07:50 -
problem with video imported into premiere
By bobspluming in forum Newbie / General discussionsReplies: 4Last Post: 28th Aug 2010, 10:26 -
Problems with Adobe dropping frames in imported video
By Texas in forum Newbie / General discussionsReplies: 1Last Post: 14th Apr 2010, 14:25 -
Imported video having troubles in Vegas 8 Pro
By stantheman1976 in forum EditingReplies: 2Last Post: 16th Nov 2008, 06:17
