im having trouble getting the files sizes i selected in autogk when using the predefined size option and even custom. i never had any problems before always worked fine till one day it didnt. im currently using version 2.48b i updated to this version after it stopped working correctly i used to be on 2.47 i think. if anyone has any ideas on whats wrong or how to fix it please help
heres a log from last encode thought it might help:
one other thing i only get the undersized files when enabling standalone support with ess chipsetCode:[4/12/2008 11:51:23 AM] AutoGK 2.48b [4/12/2008 11:51:23 AM] OS: WinXP (5.1.2600).2 [4/12/2008 11:51:23 AM] Job started. [4/12/2008 11:51:23 AM] Input file: C:\STuFF\testing.avi [4/12/2008 11:51:23 AM] Input codec: XviD [4/12/2008 11:51:23 AM] Source duration: 24mn 10s 284ms [4/12/2008 11:51:23 AM] Output file: C:\STuFF\testing_agk.avi [4/12/2008 11:51:23 AM] Output codec: XviD [4/12/2008 11:51:23 AM] Audio 1: 108 Kbps VBR MP3 2ch [4/12/2008 11:51:23 AM] Subtitles: none [4/12/2008 11:51:23 AM] Format: AVI [4/12/2008 11:51:23 AM] Target size: 175Mb [4/12/2008 11:51:23 AM] Custom resolution settings: fixed width of 512 pixels [4/12/2008 11:51:23 AM] Audio 1 settings: VBR MP3 with average bitrate: 128Kbps [4/12/2008 11:51:23 AM] Standalone support enabled: ESS [4/12/2008 11:51:23 AM] Started encoding. [4/12/2008 11:51:23 AM] Source resolution: 512x384 [4/12/2008 11:51:23 AM] Source fps: 29.97 [4/12/2008 11:51:23 AM] Analyzing source. [4/12/2008 11:59:37 AM] Source has percentage of interlacing in motion areas: 0.00 [4/12/2008 11:59:37 AM] Source has percentage of telecined patterns: 0.00 [4/12/2008 11:59:37 AM] Source has percentage of progressive patterns: 100.00 [4/12/2008 11:59:37 AM] Source has percentage of interlaced patterns: 0.00 [4/12/2008 11:59:37 AM] Source is considered to be progressive. [4/12/2008 11:59:37 AM] Output will contain 43465 frames [4/12/2008 11:59:37 AM] Demuxing audio. [4/12/2008 12:00:04 PM] Audio1 size: 19,665,846 bytes (18.75 Mb) [4/12/2008 12:00:04 PM] Overhead: 1,738,624 bytes (1.66 Mb) [4/12/2008 12:00:04 PM] Video size: 162,096,330 bytes (154.59 Mb) [4/12/2008 12:00:04 PM] Running compressibility test. [4/12/2008 12:00:04 PM] Writing the following script to C:\STuFF\agk_tmp\testing_agk_comptest.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE2.dll") movie = DirectShowSource("C:\STuFF\testing.avi",29.97).KillAudio() movie = isRGB(movie) ? ConvertToYV12(movie) : movie movie = isYUY2(movie) ? ConvertToYV12(movie) : movie cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0) fixed_aspect = 1 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0) out_width = 512 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0) LanczosResize(out_width,out_height) SelectRangeEvery(300,15) =========================================================== [4/12/2008 12:02:24 PM] Duration was: 2 minutes 20 seconds [4/12/2008 12:02:24 PM] Speed was: 15.52 fps. [4/12/2008 12:02:24 PM] Compressibility percentage is: 63.78 [4/12/2008 12:02:24 PM] Chosen resolution is: 512x384 ( AR: 1.33 ) [4/12/2008 12:02:24 PM] Predicted comptest value is: 63.78% [4/12/2008 12:02:24 PM] Running first pass. [4/12/2008 12:02:24 PM] Writing the following script to C:\STuFF\agk_tmp\testing_agk_movie.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE2.dll") movie = DirectShowSource("C:\STuFF\testing.avi",29.97).KillAudio() movie = isRGB(movie) ? ConvertToYV12(movie) : movie movie = isYUY2(movie) ? ConvertToYV12(movie) : movie cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0) fixed_aspect = 1 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0) out_width = 512 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0) LanczosResize(out_width,out_height) =========================================================== [4/12/2008 12:18:09 PM] Duration was: 15 minutes 45 seconds [4/12/2008 12:18:09 PM] Speed was: 45.98 fps. [4/12/2008 12:18:09 PM] Expected quality of first pass size: 58.52% [4/12/2008 12:18:09 PM] Running second pass. [4/12/2008 12:52:30 PM] Duration was: 34 minutes 20 seconds [4/12/2008 12:52:30 PM] Speed was: 21.09 fps. [4/12/2008 12:52:30 PM] Job finished. Total time: 1 hour, 1 minute, 6 seconds
	Hi-
 That's an important bit of information, as the XviD version used in some earlier AutoGKs gave the wrong sizes, but only with ESS chipset option enabled. I would guess that you updated your AutoGK without first having removed your XviD codec. Maybe you've done this several times. My suggestion is to get rid of XviD first via Add/Remove Programs, followed by a reinstall of AutoGK 2.48 together with the XviD included in it.one other thing i only get the undersized files when enabling standalone support with ess chipset
 And there's no need to open 2 threads about the same problem.
	The only way I was able to correct the file size issue was to stop using the standalone support option. Depending on your player and encoding settings, it likely isn't necessary anyway.
 https://forum.videohelp.com/topic343876.htmlGoogle is your Friend
  AutoGK: no subtitles in outputBy Russ_in_Colorado in forum DVD RippingReplies: 6Last Post: 5th Sep 2011, 21:20
  No sound in AutoGK output fileBy -phenom- in forum SubtitleReplies: 1Last Post: 7th Sep 2010, 10:52
  Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 5th Mar 2010, 00:50
  Incorrect Output File Sizes With AutoGKBy H3rEye51nRoam in forum DVD RippingReplies: 14Last Post: 27th Oct 2008, 11:37
  Having a porblem with output file sizes in autogkBy iamtehsux in forum Newbie / General discussionsReplies: 2Last Post: 14th Apr 2008, 12:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
