im having trouble getting the files sizes i selected in autogk when using the predefined size option and even custom. i never had any problems before always worked fine till one day it didnt. im currently using version 2.48b i updated to this version after it stopped working correctly i used to be on 2.47 i think. if anyone has any ideas on whats wrong or how to fix it please help![]()
heres a log from last encode thought it might help:
[4/12/2008 11:51:23 AM] AutoGK 2.48b
[4/12/2008 11:51:23 AM] OS: WinXP (5.1.2600).2
[4/12/2008 11:51:23 AM] Job started.
[4/12/2008 11:51:23 AM] Input file: C:\STuFF\testing.avi
[4/12/2008 11:51:23 AM] Input codec: XviD
[4/12/2008 11:51:23 AM] Source duration: 24mn 10s 284ms
[4/12/2008 11:51:23 AM] Output file: C:\STuFF\testing_agk.avi
[4/12/2008 11:51:23 AM] Output codec: XviD
[4/12/2008 11:51:23 AM] Audio 1: 108 Kbps VBR MP3 2ch
[4/12/2008 11:51:23 AM] Subtitles: none
[4/12/2008 11:51:23 AM] Format: AVI
[4/12/2008 11:51:23 AM] Target size: 175Mb
[4/12/2008 11:51:23 AM] Custom resolution settings: fixed width of 512 pixels
[4/12/2008 11:51:23 AM] Audio 1 settings: VBR MP3 with average bitrate: 128Kbps
[4/12/2008 11:51:23 AM] Standalone support enabled: ESS
[4/12/2008 11:51:23 AM] Started encoding.
[4/12/2008 11:51:23 AM] Source resolution: 512x384
[4/12/2008 11:51:23 AM] Source fps: 29.97
[4/12/2008 11:51:23 AM] Analyzing source.
[4/12/2008 11:59:37 AM] Source has percentage of interlacing in motion areas: 0.00
[4/12/2008 11:59:37 AM] Source has percentage of telecined patterns: 0.00
[4/12/2008 11:59:37 AM] Source has percentage of progressive patterns: 100.00
[4/12/2008 11:59:37 AM] Source has percentage of interlaced patterns: 0.00
[4/12/2008 11:59:37 AM] Source is considered to be progressive.
[4/12/2008 11:59:37 AM] Output will contain 43465 frames
[4/12/2008 11:59:37 AM] Demuxing audio.
[4/12/2008 12:00:04 PM] Audio1 size: 19,665,846 bytes (18.75 Mb)
[4/12/2008 12:00:04 PM] Overhead: 1,738,624 bytes (1.66 Mb)
[4/12/2008 12:00:04 PM] Video size: 162,096,330 bytes (154.59 Mb)
[4/12/2008 12:00:04 PM] Running compressibility test.
[4/12/2008 12:00:04 PM] Writing the following script to C:\STuFF\agk_tmp\testing_agk_comptest.avs
LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dl l")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrain SSE2.dll")
movie = DirectShowSource("C:\STuFF\testing.avi",29.97).Kil lAudio()
movie = isRGB(movie) ? ConvertToYV12(movie) : movie
movie = isYUY2(movie) ? ConvertToYV12(movie) : movie
cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples= 10,aspect=0,threshold=0,samplestartframe=0,leftadd =0,rightadd=0,topadd=0,bottomadd=0)
fixed_aspect = 1
c_width = width(cropclip)
c_height = round(height(cropclip) / fixed_aspect)
input_par = float(c_width)/float(c_height)
input_par = (input_par > 1.4) || (input_par < 1.25) ? input_par : (4.0/3.0)
out_width = 512
out_height = round(float(out_width) / input_par)
hmod = out_height - (floor(out_height / 16 ) * 16)
out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
autocrop(movie,mode=0,wmultof=4,hmultof=4,samples= 10,aspect=new_aspect,threshold=0,samplestartframe= 0,leftadd=0,rightadd=0,topadd=0,bottomadd=0)
LanczosResize(out_width,out_height)
SelectRangeEvery(300,15)
[4/12/2008 12:02:24 PM] Duration was: 2 minutes 20 seconds
[4/12/2008 12:02:24 PM] Speed was: 15.52 fps.
[4/12/2008 12:02:24 PM] Compressibility percentage is: 63.78
[4/12/2008 12:02:24 PM] Chosen resolution is: 512x384 ( AR: 1.33 )
[4/12/2008 12:02:24 PM] Predicted comptest value is: 63.78%
[4/12/2008 12:02:24 PM] Running first pass.
[4/12/2008 12:02:24 PM] Writing the following script to C:\STuFF\agk_tmp\testing_agk_movie.avs
LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.d ll")
fixed_aspect = 1
out_width = 512
[4/12/2008 12:18:09 PM] Duration was: 15 minutes 45 seconds
[4/12/2008 12:18:09 PM] Speed was: 45.98 fps.
[4/12/2008 12:18:09 PM] Expected quality of first pass size: 58.52%
[4/12/2008 12:18:09 PM] Running second pass.
[4/12/2008 12:52:30 PM] Duration was: 34 minutes 20 seconds
[4/12/2008 12:52:30 PM] Speed was: 21.09 fps.
[4/12/2008 12:52:30 PM] Job finished. Total time: 1 hour, 1 minute, 6 seconds
one other thing i only get the undersized files when enabling standalone support with ess chipset
Please don't doulbe post. Your other post has already been answered.
Google is your Friend
AutoGK: no subtitles in output
By Russ_in_Colorado in forum DVD RippingReplies: 6Last Post: 5th Sep 2011, 20:20 -
No sound in AutoGK output file
By -phenom- in forum SubtitleReplies: 1Last Post: 7th Sep 2010, 09:52 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 4th Mar 2010, 23:50 -
Incorrect Output File Sizes With AutoGK
By H3rEye51nRoam in forum DVD RippingReplies: 14Last Post: 27th Oct 2008, 10:37 -
Having a porblem with output file sizes in autogk
By iamtehsux in forum DVD RippingReplies: 2Last Post: 14th Apr 2008, 10:42
