Hi ,
I have a IEEE 1394 port : firewire .. and I used to capture from my video camera using it ..
The last time I tried to capture ( and it worked ) was like 2 months ago ..
But 2 days ago I wanted to capture some' .. Whenever I try to capture ( using Movie Maker ) .. it turns to " not responding " .. So whats the problem .. and how can I fix it ..
I'm 100% sure that I will find the solution with you guys .. I never ask you some' .. and back with nothin' ..![]()
But I got two points :
1- My PC is powerful as a normal-use PC ( see my info - like 2 gb ram .. etc ) .. so I don't think the problem is caused by a full ram problem or so ..
2- I tried to capture using other progs ,, in the past it worked .. and now it wouldn't ..
3- When I connect the camera .. It shows me that there's a camera connected .. But when I try to capture![]()
waiting for y'all ..
thanks ..
Results 1 to 10 of 10
Try using WinDV and manual camcorder controls.
http://www.kiva.org/about -
Hi ..
cool , now that's great .. this one does work ..
but does it have the best quality ?? I bet it does ..
thanks . -
WinDV makes an exact duplicate of the data on tape (i.e. first generation copy) every time.Originally Posted by ZaYoOoD
Movie Maker 2 can too only if you know how to output as DV-AVI not WMV.Recommends: Kiva.org - Loans that change lives.
No, you need to stop it manually.Originally Posted by ZaYoOoD
One warning on WinDV, it doesn't behave well when the disk becomes full.Recommends: Kiva.org - Loans that change lives.
OK ,, another question .. whats the problem with windows movie maker ?? why doesn't it work .. there must be a reason that can be fixed
For some reason machine control (e.g. stop, play, rew, ff, pause) isn't working.Originally Posted by ZaYoOoD
IEEE-1394 connect is one process under XP/Vista networking.
DV video streaming is a second process under DirectShow
DV machine control is a third process.
WinDV can work with just the first two working.Recommends: Kiva.org - Loans that change lives.
aha ,, I see ..
OK .. thanks alllot .. I got it fixed all by your help ..
thanks again ,,
and once again .. I ask a question in this forum .. and I get the best answer for it..
thanks
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
VHS tape capture "flickering" - Intensity Pro Capture Card
By mofaster in forum Capturing and VCRReplies: 2Last Post: 31st May 2009, 12:56 -
Circles turns to "eggs" in video when converting with srt subs
By grossmisconduct in forum SubtitleReplies: 1Last Post: 19th Nov 2008, 17:13
