My dvd ram drive on my computer will not burn blank discs. Nero's burn screen acts like it doesn't burn dvds. Imgburn says theres a non reportable drive problem. The computer shows it as a CD-Rom.
I've done firmware upgrades and downgrades, no luck. Suggestions?
Results 1 to 10 of 10
Take it back to the shop where you bought it?Imgburn says theres a non reportable drive problem.
Suggestions? -
I've never been able to get either of my LG drives to work with RAM. There should be a special driver or something on the disc that came with the drive to enable RAM. I tried it once and it sucked....never investigated further because I don't need RAM anyway....but I still wouldn't trade either of my drives for anything short of a Pioneer...my LG's are awesome...and the are pretty damn old too.
You need a ram driver:-
did your burner come with a disc of software as I think its on their.
Try also going into control panel and uninstalling the burner and restarting your PC
here it is:-
http://www.bha.co.jp/en/support/faq_dvdram/index.html
and I think its on the cd that comes with lg burners, its something to do with BHA but know it worksPAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Thanks victoriabears, but its not for my drive. It is for othe GSA drives.Originally Posted by victoriabears
It appears to be a media issue. My LG DVD-RAM turns into a CD-ROM when using Verbatim dvd-r media code: MCC 03RG20.
I put in a blank Sony dvd-r media code:SONY16D1, and it burned it. Its funny cause I've burned 100s of verbatim dvd-rs with this drive. Infact, I only use Sony or Verbatim dvd-r. These Verbatims are less than a week old, their from a 100pk I purchased at Micro center. -
Some 100 packs of VERBATIM DVD-R w/media id "MCC 03RG20" have been flaky. I had some discs only burn at 4x speed, go figure! Check out Cdfreaks.com media section and you can find members there who are guru's when it comes to finding the good VERBATIM spindles of dvd media.
Check in Device Manager if your drive shows up correctly.
If Windows Explorer shows it as CD-Rom - that really doesnīt matter. Could be because of the last disc used - Windows acts rare on that.
Itīs like when it "remembers" the title of the last CD/DVD - even if you changed it various times.
Check in Device Manager if there are weird upper or lower filter installed, or called, but not there anymore. Delete them in the registry. Reboot.
Also check if DMA is still enabled.
This all has nothing to do with RAM or no RAM. Maybe you uninstalled another burning program, and drivers (lower / upper filters) are still activated - but uninstalled or corrupted -
Its funny my 4 yr old Sony GX7 recorder has no problems with these Verbatims.Originally Posted by budz
As we all know LG doesn't upgrade their firmwares on their dvd burners to match the newer dvd media id's, they just come out with new models. I should have added that although some of those discs burned at only 4x speed on some of my dvd burners, it did burn at 8x speed with my SATA SAMSUNG S203B drives. Go figure!Originally Posted by pinetop
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 15:17 -
Verbation 16x and GSA-S10N drive
By webstar in forum MacReplies: 4Last Post: 23rd May 2010, 01:15 -
LG GSA-H55N drive doesn't load
By Cheesie in forum DVD & Blu-ray WritersReplies: 11Last Post: 20th Aug 2008, 06:23 -
Problem with a Flash Drive
By The Monkees in forum ComputerReplies: 5Last Post: 19th Nov 2007, 18:42 -
Slow DVD drive (LG GSA-H42N) problems
By cosmo09 in forum DVD & Blu-ray WritersReplies: 2Last Post: 16th Sep 2007, 01:51
