hi, i have copied a movie file from my vcd. as usual, i will split the audios if there is two audio sounds using virtualdub. however, this time, i failed to split the two audios. when i checked the movie file's properties, it indicate the audio in mono. but, when i play with windows media layer, i try to adjust the left and right speakers, i can choose the audio that i wish to listen to. anyone can help me to fix the problem?![]()
Results 1 to 10 of 10
When you say yuou can choose the audio you want to listen too are they two different audio tracks?
Use Virtualdub to demux the audio into a WAV file. Use Audacity (it's free) to split the WAV file into separate left and right channels. Convert the separate WAV files back to MPEG-1 layer II audio for VCD using BeSweet or something similar.
yea, one is a cantonese track the other is a mandarin track.Originally Posted by thecoalman
can you please explain a little how to demux into wav file?Originally Posted by jman98
hi, think i have successfully remove the track that i dun want, though im not sure whether my method is correct or not. i just press the "x" for the track that i dun want. correct me if im wrong.Originally Posted by sharmine
then, i tried to convert to mpeg1 layer ii as u have metioned earlier, but..i can't find the file format for mpeg1 layer ii in besweet.
Mono to Stereo in MPC?
By jg84 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 13:56 -
Mono / Stereo sound
By Anonymous16 in forum AudioReplies: 3Last Post: 13th Nov 2011, 20:09 -
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 06:45 -
VHS Mono to Stereo
By Yaemish in forum AudioReplies: 2Last Post: 22nd Dec 2008, 11:42 -
mono to stereo?
By wingfan in forum AudioReplies: 5Last Post: 22nd Nov 2008, 13:44
